What Toda or JUN cams will allow me to past emmisions...
Old Aug 2, 2002 | 05:09 AM
AutoXsi2000's Avatar
Default What Toda or JUN cams will allow me to past emmisions...
This is for a 00'Si. Which stage, 1, 2, or 3? Of course I'll be changing out valves, valve springs, and retainers.
Old Aug 2, 2002 | 08:46 AM
earl's Avatar
Default Re: What Toda or JUN cams will allow me to past emmisions... (mano77)
Based on their spec, no Jun should pass smog. Toda A should pass as it's specs match the Type R's. I'd go with the R's if they are cheaper.
Old Aug 2, 2002 | 02:27 PM
TodaSi's Avatar
Default Re: What Toda or JUN cams will allow me to past emmisions... (earl)
I'd get Toda Spec A cams.
ITR intake springs
your 99 Si intake springs on the exhaust side
titanium retainers
Sweet set up.
Old Aug 2, 2002 | 08:02 PM
01PYITR's Avatar
On here I have heard many stories that If you have Jun3 you can pass emisions testing but you would have to back everything down ot Zero, cam gears, fpr set to lean and what ever else can be set back then when done testing return items back to power again
Try a search for more info.
Old Aug 3, 2002 | 10:29 AM
Al Bundy's Avatar
Default Re: What Toda or JUN cams will allow me to past emmisions... (01PYITR)
i don't see why jun's can't pass smog as the non vtec lobe is the same size as the gsr non vtec lobe. As mentioned, set everything back to zero and it should be fine
Old Aug 4, 2002 | 08:25 AM
Chubz's Avatar
Default Re: What Toda or JUN cams will allow me to past emmisions... (thangdovu)
the JUN III lobes (non vtec lobes) are bigger than GSR non vtec lobes, they are bigger than ITR non vtec lobes. The primary use for the JUN cams are on b16 heads, thats where they did all their RD from.
vtir
Jul 3, 2006 08:11 PM
^AnDre^
47
Jan 30, 2005 01:04 AM
gary201147
Aug 7, 2002 10:42 PM
done
Aug 3, 2001 02:40 PM
