valve springs
Old Dec 4, 2008 | 11:05 AM
oldskool89ef's Avatar
Default valve springs
need some help with 1.8 integra gs stock cylinder head. i need to know which spring is for the exhuast and intake. i was a tool for not paying attention when tearing down the head. any help would be appreciated.
Old Dec 4, 2008 | 06:46 PM
92IntegraPOS's Avatar
exhaust valves are always bigger
Old Dec 5, 2008 | 05:38 AM
OvernightPartsFromOZ's Avatar
all the valve springs should be the same.
Please don't tell me you are rebuilding an engine and stuff and reusing stock valve springs. Thats just asking for failure.
If you had lighter valve springs on one side, the lighter would be much more prone to valve float @ higher engine speeds.
Old Dec 5, 2008 | 06:02 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
All valve springs are NOT the same. They have different part numbers for intake and exhaust. I'm not sure which is which on the B18B engine. On B18C1 GS-R engines, the intake side actually has dual valve springs. On the B18C5 Type R engine, all valves have dual valve springs, and the exhaust springs are actually the same (same part number) as GS-R intake valve springs.
Old Dec 5, 2008 | 07:07 AM
tilegend's Avatar
i'll post up the specs for you:
(B18A)
Valve Spring: Free Length:
IN 42.36 (1.668)
EX 40.09 (1.578)
(B18B)
IN 41.27 (1.625)
EX 44.32 (1.745)
Old Dec 5, 2008 | 07:17 AM
is it just a size difference? I would be surprized to see an actually spring pressure difference.
I'm coming from the pushrod world.
Old Dec 5, 2008 | 07:26 AM
Community Builder
I'm sure there is a spring pressure difference. Look at B18C1 engines, which have dual valve springs on the intake side only.
DOHC engines are wayyyy different than pushrod engines with a single cam buried down in the block.
State.of.Prime
Oct 17, 2010 01:43 PM
VtecLsEater
Feb 27, 2009 11:02 AM
danthemang3
Jan 16, 2006 06:02 PM
