locate and identify wires
Hello having trouble locating these wires. im preparing for my swap.
i neeed the color and location of these wires on a 94 accord ex sedan with f22b1 motor. if someone could provide me with these id be greatly appreciative.
IAT
MAP
EGR Lift solenoid
H02s
ECT switch A
IAC valve
IAT
MAP
EGR Lift solenoid
H02s
ECT switch A
IAC valve
IAT= On the back side of your intake manifold.
MAP= on top of the throttle body
EGR= Pass. side torward the front of the intake manifold
O2 sensor= in the a-pipe under the car just past the oil pan.
ECT= There is one in the cyl head under the dist. and one in the upper radiator hose neck.
IAC= Back side of the intake manifold by the throttle body, just behind the TP sensor.
chad174
Jan 10, 2003 07:04 PM
