Anyone fitted an oil catch tank/oil air separator in their DC5?
mounting the oil catch line to the valve cover /intake is NOT the proper way...
it needs to be mounted to the PCV...which is on the water pump housing
here its is mounted to the PCV & to the valve cover
RBC IM
more info
http://forums.clubrsx.com/showthread.php?t=262065
see it works
edit - 3/8" =.38" 10mm =.39" & -6an hose equals 3/8"
Modified by adirondackR at 9:45 AM 2/28/2006
RBC IM
more info
see it works
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boilermaker1 »</TD></TR><TR><TD CLASS="quote">You need a vac source. Either:
PCV----- Can-----IM
OR
PCV and Crankcase breather ----- Can ----- IM</TD></TR></TABLE>
i was told bu 2 different sources you DON'T need a vacuum...infact the best way to do this would be with a baffled oil catch can with a pcv valve on it connected to a breather (remove/relocate OEM stock pcv valve)....with NO other line (running to IM)
works better if you eliminate the IM connect & run a open system thereby not introducing blow-by vapors back into the IM
I have just verified this with SEVERAL people including well know engine builders
EDIT - someone very experienced w/K motors told me to go closed loop with the connection to the IM
Modified by adirondackR at 8:02 PM 2/28/2006
Modified by adirondackR at 8:54 PM 2/28/2006
PCV----- Can-----IM
OR
crxb16sir
17
Dec 16, 2009 12:27 AM
drock4688
Jan 14, 2009 12:34 PM
1992TegGsr
Sep 7, 2008 07:19 PM
has anyone done this yet?
