F/s bunch of all motor B stuff
B16 Head- milder Ported and Polished by z-tech. Stock type-r valves valves, Supertech Spring and retainers w/valve job. USED $600
Peak-Performance B-series vtec cams with Peak cam gears- Low miles looks to be less than 5000 miles put on them. USED $300
Specs on cams: Intake: Duration: 255° @ 0.05in Lift: .496in
Exhaust: Duration: 256° @ 0.05in Lift: .494in
Edelbrock Victor-X intake manifold for B16/B18c5 4764- Used Comes with Hondata gasket. USED $250
Skunk-2 throttle body- 70mm no tps or map. USED $130
BDL B-series fuel rail- bronze. USED $75
RC 310cc injectors- USED $200
Rage B-series Tri-y header-no dents not smashed on bottom great condition. USED $400 or $425 with Omni test pipe cut to replace cat.
Greddy sp2 for dc2- USED $150
Endyn B-series 81.5mm B18b Roller Wave pistons- N/A high compression compression/height 1.185 comes with pins and lock needs rings, needs rings under 5000 miles. USED $150
Eagle ls big bolt-Used $100
Hondata s100 comes with ecu from hondata- $200
Fluidampr- For B-series, street version-a/c p/s. USED $200
AEM fuel pressure reg.- Red $50
ARP-Ls/Vtec Head Studs USED $40
Moroso- Alumi 5.5 quart oil pan with ls pick up used $130
Drive Shaft Shop- B-series Old stage 3 axles don’t need hubs for these. $400 (rated at 600hp)
Hasport- B-series engine, tranny and back mount. Fits EG and DC2 $200
Fidanza-B series Flywheel 12lbs. USED $50
Exedy- B series flywheel 7lbs USED $100
Avid- Traction bars for EG and DC2 $200 USED
pm for details and pics
Edited prices lower to move please don't pm me if you are trying to low ball me by an extreme amount Thanks
I am interested in a lot of things in this thread including; Axles, Traction Bar, Mounts, Fuel Rail and Pressure regulator. Give me a call 240 277 7648 very interested if you cut me a good deal
Johnsonn
Jun 18, 2017 07:27 PM
vaporboy12
Apr 28, 2009 06:32 PM
