couple Qs bout motor????
whats up every 1.... just picked up a 90 hatch the other day....so i changed out the spark plugs and when i pulled 1 of them out it had oil on da plug reason for concern????also da car has a har time starting up when itz cold outside but will starrt up when its warm outside any ideas on what that could be???? ne feed back is thankful....
the gasket thats above the spark plug is bad (the one that touches the valve cover)
the starting issue you need to check the starter mine was going through the same problem till i pulled it apart and cleaned it up
the oil on your spark plugs is from the rubber gromits on your valve cover and i had a 91 hatch that had a hard time starting and i replaced those gromits out of curiousity and it fixed the problem so maybe try replacing the valve cover gasket and those gromits they come in a kit at a parts store and that should fix your problem and its a cheap fix
For more help with these two sets of seals, see http://honda.lioness.googlepages.com...sparkplugtubes
Consider starter problems, especially starter solenoid contact problems, using http://www.hondasuv.com/members/showthread.php?t=20252&
For a used car just purchased, you really ought to put in new OEM wires, plugs, dizzy cap and rotor. It is amazing how often these by themselves will fix running problems. And only OEM. They do pay for themselves in the long run.
Drain, fill, and purge the cooling system, too, or just top off and purge for now. Certain engine sensors need to be immersed in coolant to work right.
Have you checked the ECU for codes?
CalhounBoi
Oct 1, 2006 05:25 PM
