Swap Troubles.. Please take a look
alright guys.. so i put a new motor in my friends 91 four door
we put in a d16a6 automatic but of course put the 5 speed transmission on it as well..
everything is in, and wired up.. except
for the big *** plug (if you are looking at the motor with the hood up, it is the big plug in the back right, normally where the resistor box is at)
the wiring harness that came with the motor was cut from the injectors going over there..
first Q
does anyone have a wiring pinout for this?
next.. the motor we pulled out (which we are using that same computer) had a resistor box wired up to it as well.
second Q
on this new motor and new harness there is no place for a resistor box, unless it comes off the 11 wires coming from the injectors going to the top right to where that big plug is at also..
basically.. i know this is vauge, and i will help out with any other information
long story short.
i have the motor all plugged in. a resistor box sitting in my hand, no where to plug it up. 11 wires coming from the injector area , and are supposed to go up near the brakes master to that plug over there..
help!
first Q
second Q
long story short.
help!
gata get an uncut wiring harness if you dont know how to rewire one (its a pain with little experience) and if its obd0 it needs the resistor box so search up wiring diagrams and see where its supposed to go and you might be able to just pick up a plug and wire that into it as is
91efbluehatch
13
Aug 3, 2011 07:18 PM
