Toda ITB's to suit P72/GSR head, Motec M4 Pro, Wideband Enabled ECU & Modifed Dizzy
Selling my Motec M4 pro set-up i had running my B18C with a modifed distributor, its wideband enabled and in perfect working order having been sent to motec for a check over, its wired into a obd2a chassis and is plug and play except for a few wires leaving simple mods to an existing loom opposed to forking out for a custom, the 3 wire distributor pick-up and lambda that can be seen sticking outside the ecu chassis with the data cable connection, also a modifed b series distributor that is converted to a 3 wire with a DTM plug connection to suit, that i had a M&W/motec fed COP set-up running.
$1500.00 shipped to your door OBO
If required i have a Motec IEX igntion expander allowing this ecu to run a 4 channel CDI unit available aswell at extra cost.
Toda ITBS, used but in perfect condition, to suit GSR/P72 heads, look mint with a good clean, includes filter socks as pictured.
$1400.00 Shipped to your door OBO
PM me for any info or questions regarding these items.
Thanks.
Thanks.
