Read this people help!
Does a honda s2000 cluster fit in a del sol? also if so do anyone have any write up on it?
Second Question: Is my car that is a 93 del sol called an eg or an ek ? If so is all the eg's cluster pinout diagram the same?
thanks!
thanks!
First of all, read the stickies before posting: https://honda-tech.com/forums/showthread.php?t=2407755
Second, an s2000 cluster will not plug-n-play to a del sol nor will it bolt in as far as I know. Some people have modified the cluster to make it work in different cars, but it isn't a simple process as far as I know.
Third, "EG" is the common name used in reference to a 92-95 civic and "EK" is the common name used in reference to a 96-00 civic. These names ACTUALLY refer to the letters in the Japanese-made Hondas' VIN numbers. So in reality our civics are Ej6's etc (whatever your VIN says).
