Anyone here drag with an auto?
I know its a waste of time but ill try, anyone here drag their automatic civic? I got mine and it seems whats killing me is the launch, dont really know what else to do to get off the line better. I tried preloading, brake launching ahd just plain ole smashing it nothing showed any clear advantage. Once im up and running im good to go. Ill have a turbo on soon enough just tryin to see if anyone else out there has any ideas.
racer stev pondered this question before.
problem is honda squish boxes cant handle the power our cars make in stock trim. let alone hanging a hairdryer on them.
to get your car to leave higher you need a higher than stock stall speed converter.
im not sure if level 10 parts are still available.
joe im showing that i am older than you, were calling them squish boxes when my t type started slipping back in 95 and i know that term was there long before that.
think about it, a slipping trans = squish box. nice soft shifts. he hee
get back to work.
get back to work.
ive personally seen them hold 160-170hp for 2-3 years. Just change the fluid every 10k miles and run an external cooler nad remeber to lift if your full throttle when shifting. I think level 10 still has stuff but they arent worth it for an extra 750rpms they give you. Ill have a 14b turbo so brake launching it will hold me at full boost for the launch. Absolute will be doing my tune when its done also
Back in my day, we called them slush boxes. I won't tell you how long ago that was...there was always the old slip and slide powerglide too. Oh ya, they had cast iron cases too. My 61 Chevy had one.
AEM F/IC is what it will be tuned on. The purpose of my auto is becasue of all the city.traffic driving i do way to much to be shifting all the time. And if ya got a stick shift ya gotta lift to shift to no different, cept i have no chance of missing a shift
As far as the OBD1 civics.....I haven't had much luck with them, unless you are running a complete OBD1 civic setup....trans, engine, etc. since the OBD1 civic ecu only controls part of the auto tranny functions. If you have an OBD2 car and want to use a conversion harness......not gonna happen.
no, thats just my name on all the forums, i have a bastard y8 motor, not really sure on the internalls as its a JDM block that i cant find and damn specs for but its a y8 head on it, its a 97 4dr EX. THe OBD1's actually can be chipped and tuned so not sure where you got that info you just cant convert OBDII auto to OBDI
That's not what I said. I said if he has an OBD2 auto and wants to convert down and run the OBD1, then it's not going to work auto. If he has the entire OBD1 setup, then he can tune it auto.
AllMoToRB18c
Mar 4, 2014 03:32 PM
AtoZ
Paint and Body
Apr 19, 2010 03:02 PM
