Charging Issues
Old Dec 3, 2008 | 06:59 PM
alyssasdaddy's Avatar
New User
Default Charging Issues
I have searched google, and this forum found nothing that even explains my problem.
I have a 91 accord stock. The charging system has serious issues it charges and the does not charge now more not then does.
What i have done:
Changed Battery, Alternator, Battery cables, Engine Grounds, and fusiable link.
What i have done testing wise.
I have a alternator tester which is also a battery tester basically just a volt ohm meter. I tested all wires coming from alternator and the blk/yel. Has power The wht/blu. has power. I have opted to not test the wires that go to ECM. The charge wire is producing 14.4 volts at idle when the wire is disconnected from system. Also produces the same when the battery is disconnected and when i Connect it to battery while running.
When i shut off car and restart the alternator is no longer charging untill i disconnect the battery and reconnect.
Keep in mind this is a new battery. The alternator is used however i bought a new one when this one failed and it produced the same results so i returned it. The old on was test at my local autozone and the machine says its working. This and one other alternator i have for the car. Including the new alternator this is 4 that are all doing the same thing.
I also check every fuse i came across (Both fuse panels) and all are good.
Any suggestions?
Chris
Old Dec 4, 2008 | 03:22 AM
Duane_in_Japan's Avatar
Does your car have an ELD, this is a Honda item. I also only like new or rebuilt OEM alternators.
Old Dec 4, 2008 | 03:51 AM
YeuEmMaiMai's Avatar
problem is the load detector
Old Dec 4, 2008 | 08:28 AM
New User
Could anyone tell me where i can locate the ELD or at least give me a idea of where i should start looking.
The alternator is used but in good condition, I did not want to put out the money for a new one. I have already spent a lot of money on this car.
Also is there a way to bypass the ELD
PS:
Thanks for the response
Old Dec 5, 2008 | 08:37 AM
New User
Is it part of the ECU or is there a module that can be replaced? Is there a way to bypass that circuit all together?
Old Dec 5, 2008 | 06:31 PM
hondadude's Avatar
Maybe this link will help you;
FWIW; I think the ELD IS available as a separate unit now
File Type: pdf
Old Dec 5, 2008 | 09:32 PM
New User
Thanks for that information i will give it a shot tomorrow.
Old Dec 12, 2008 | 08:20 AM
New User
It was that part, I have found that some accord fuse boxes can be disassembled and some can not, The on i got that part from came apart easy mine did not.
The car runs, Charges, and did not take the trip down green mile.
Old Jan 2, 2009 | 08:49 AM
New User
Default Re: Charging Issues
*Update
The car still has the charging problem, When i did that it worked for like a day, then replace the fuse box. It was still only showing 9-10 volts on the charge.
I sold the car as is informing them of the problem that the car has, The car was later totaled a block away from me.
Old Jan 2, 2009 | 09:47 AM
P_Adams's Avatar
Originally Posted by alyssasdaddy
*Update
Unorthodox, but it's finally fixed
P
Old Aug 28, 2009 | 03:24 PM
New User
Another update on that car is when it got totaled they gave it back to me and i took it to an undisclosed place and emptied about 2000 rounds of ammunition into it, The car has been retired
Old Aug 28, 2009 | 07:33 PM
P_Adams's Avatar
I think I caught that on the History Channel. Some Gunnery Sargent type was emptying a .50cal into it.......
Made for good TV
P
Speed--Freak
15
Jan 5, 2022 05:22 AM
fix_my_car
Oct 10, 2010 06:08 PM
Tommy_Gunns
Sep 11, 2009 12:10 AM
Syndacate
Aug 14, 2007 05:10 PM
bluegoo
Nov 17, 2002 09:39 PM
