maybe ecu maybe distributor
Old Dec 3, 2008 | 06:24 PM
Neekstar's Avatar
Default maybe ecu maybe distributor
so a few weeks ago i swapped a 96 b18b1 into my eg 94 civic and i got a obd1 p75 ecu
so after my car has been running for a little bit (10 miles or so) if i would put alot of throttle under 3krpm it would start to bog like the timing was off but when i got over 3000k everything would be fine and today i was on my way to school and it started doing it and when i would get to a stoplight the idle would be rough and it when i would put throttle it would not want to raise in rpm for a few seconds.
then my car stalled at a stop light and it would still crank but it wouldn't turn over.
so i towed it to my cousins house and started checking the distributor and now im not getting any spark when i pull the spark plug cable off the distributor and held it close to the distributor and cranked it
followed the helms manual on the ingition coil test and it was ok
and im not getting any cel codes
any ideas HT i need your help
Old Dec 3, 2008 | 08:07 PM
Shaggy143Music's Avatar
It could be your ICM inside the distributor. I had the same problem. It ended up being my distributor but I also had a CEL on. Try testing the ICM.
Old Dec 3, 2008 | 09:41 PM
96-EJ6 B18C's Avatar
If the ICM is good, the yellow/green wire coming off the distributor connector should have about 10v with the key on and the engine off. Have you pulled the cap off the distributor yet?
Another thing to look at is the harness ground on the back of the thermostat housing, if that is loose or disconnected it can cause all kinds of problems.
Old Dec 3, 2008 | 10:26 PM
Neekstar's Avatar
ive pulled the cap of distributor checked the ignition coil and checked all the wires going into the ICM they all gave off the right voltages i did the icm check that the helms manual showed me how to do
Old Dec 3, 2008 | 10:59 PM
teamworxek9's Avatar
have you checked all the grounds. most problems after a swap stem from bad grounds.
Old Dec 4, 2008 | 08:55 PM
Neekstar's Avatar
ok i just checked all the grounds including the one on the thermostat housing and they are all connected
Old Dec 4, 2008 | 09:04 PM
Is the rotor nice and tight on the distributor shaft? Maybe test continuity between the center post of the cap and the coil output terminal.
One more thing...check for a broken timing belt, if that breaks the cams don't spin and neither does the distributor and you get no spark.
BIGPAPAWACK
10
Aug 23, 2010 11:51 AM
rodvang
Jan 9, 2008 05:45 AM
ejprimo
Apr 25, 2003 10:20 AM
FitCRX
Feb 19, 2003 08:23 AM
