b20v vs. lsvtec
Old Dec 3, 2008 | 05:13 PM
bijou's Avatar
Default b20v vs. lsvtec
i know you guys have mad topics on this but i have most of the money to get this swap trying to deciding which to get a b20 or ls and im trying to get alot of torque out of these engines which one is the best???
Old Dec 3, 2008 | 05:15 PM
IhateworkingoncaRs's Avatar
well, there the same engines, except the b20 has bigger bore which will have more torque.
Old Dec 3, 2008 | 06:09 PM
liam821's Avatar
25 Year Member
b20 has a gsr oil pump (better)
b18 has stronger sleeves (better)
b20 has a 84mm bore
b18 has a 81mm bore
both blocks externally are almost identical other then the block stamp
other then that they are almost identical.
The b20 will make more torque, 2 liters vs 1.8.
captivateeg6
Dec 7, 2009 12:24 PM
NA JDM GSR
Apr 27, 2006 05:25 PM
SLR ef9
24
Jun 13, 2005 09:44 PM
russian_racer
16
May 13, 2003 11:51 PM
civicdragger818
Feb 17, 2003 06:53 PM
