Honda S2000 Honda S2000
Looking for F20c specs
Old Dec 3, 2008 | 05:10 PM
CR3X's Avatar
Default Looking for F20c specs
Hi just looking for some basic engine specs on the s2000's f20c.
If anyone knows some of these please contribute. Ive searched the internet and some details are iffy and hard to come by.
Crankshaft: material, strength, stroke, rod journal size, main journal size.
Connecting rods: material, style, bolts, length, width, length, weight.
Pistons: material, style, coating, pin, dome/dish volume.
Piston rings: top,second,oil ring size and material, end gaps.
Cylinder head: intake and exhaust port volumes, chamber volumes, flow data.
Compression ratio: compatibility with boost pressure and pump gas.
Camshaft specs: Duration @ .050, lift, lobe separation angle.
Valves: Diameter, length, material
Valve springs: Pressure @ installed height.
Retainers: Material, Keeper type.
Rocker arms: Rocker arm ratio.
Intake manifold: Runner length, Plenum capacity, Flow data.
Throttle body: Bore.
Fuel system: Injectors, pump specifications, fuel pressure
Ignition: Spark wire resistance, Spark plug heat range, gap measurement.
Exhaust manifold, design, runner length, runner diameter, material.
Oil system: Pump design and drive system, volume/pressure, coolers, oil type.
Cooling system: coolant pump design, pump drive system, radiator.
I think that's most of it. I don't expect anyone to know everything but if you know even one please lemme know. Thanks for your help!
Old Dec 3, 2008 | 05:17 PM
AMS MIKE's Avatar
google! took less than 1 minute
http://en.wikipedia.org/wiki/Honda_S2000
http://en.wikipedia.org/wiki/Honda_F20C_engine
http://www.jdmenginesamurai.com/engi...ngine_f20c.htm
Old Dec 3, 2008 | 05:21 PM
CR3X's Avatar
Thanks for the effort but I noticed you picked the first few google results. To top it off those results which I researched came up with little to none of the information Im looking for and listed.
Old Dec 3, 2008 | 08:36 PM
RA102725's Avatar
Icon2
No need to be a tool about it, none of those pages answered his questions. Don't treat this guy like he asked a stupid or commonly asked question.
OP,
If you can't find the info you need online, PM me and I'll try to get you in contact with somebody I know from Honda who could find out for you.
Old Dec 4, 2008 | 07:20 AM
CR3X's Avatar
Thanks Mikesta. I will give Honda a call and see if they can help me out on some of this. I was surprised this info was so scarce on the internet being the s2000 is Honda's FR masterpiece, but hopefully Honda can answer most of these questions.
Old Dec 4, 2008 | 09:58 AM
RA102725's Avatar
heres the website you should be looking at, regular consumer help won't do much for you.
http://www.hondaresearch.com/index_flash.cfm
Old Dec 4, 2008 | 10:27 AM
honeybadger's Avatar
I believe the service manual *might* have some of that info you are looking for.
Old Dec 4, 2008 | 10:11 PM
AMS MIKE's Avatar
LMFAO
bambam
29
Sep 16, 2012 02:36 PM
fastludeh22
Honda S2000
Oct 24, 2007 08:43 PM
hahaha38
Jun 23, 2007 01:53 PM
Ponyboy
May 26, 2007 06:22 PM
Mr. Vapor
Jan 16, 2003 09:34 PM
