how to - install ITR wheel - MY way
Old Dec 3, 2008 | 05:07 PM
Turbo Dan's Avatar
Default how to - install ITR wheel - MY way
here is my first try, on my old crx!
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/project-thread-turbo-dan-sir-front-end-crx-how-installing-itr-wheel-1953144/
if you read this thread first this will make more sense.
couple pictures of the wheel that came with the car when i bought it, a very nice wheel btw and i never thought i would like a grant wheel so much.
here is what the grant hub looks like, its a pile of ****
hub removed (notice the signals cancel switch still in tact)
new hub
this is the tricky part, i had the nrg short hub taken to a machine shop and i created a new bolt pattern, the two yellow circles are the holes i had added. The ITR wheel bolts to the hub with 4 bolts and the pattern is just that.
with some modification to the wheel to match up the holes and its really to install
here is the wheel mounted, all i had to do was hook up the horn (simple two wire plug and play)
here is a shot of the distance, same as a stock wheel, no reaching for the signal lever, and still keeping the stock signal cancel switch unharmed.
rest of the pics i was just trying to get a good shot of it with the bad parkade lighting
Old Dec 3, 2008 | 05:09 PM
irev210's Avatar
Why go through all of the trouble? Why not just put ITR wheel on EF spline?
No hub needed
Old Dec 3, 2008 | 05:11 PM
ONE-CAM-EF's Avatar
not bad..it looks pretty good..
Old Dec 3, 2008 | 05:12 PM
Turbo Dan's Avatar
No hub needed
no hub needed?
umm, not sure what youre talking about but i think you need to do a bit more research.
Old Dec 3, 2008 | 05:32 PM
mike9571's Avatar
No why didnt you just bolt the wheel straight the the ef spline? Would of made life easier.
Old Dec 3, 2008 | 05:36 PM
Turbo Dan's Avatar
the itr wheel doesnt work like this
the itr wheel comes with an itr hub, that looks like this nrg hub, very similar.
now if you dont use the stock itb hub you need to substitute something in its place, i use an nrg short hub.
if you use the stock itr hub that comes with the wheel, it doesnt fit the steering rack and leaves you with no threads to tighten it.
to overcome this problem, some have shaved or removed the signal cancel switch.
so to make this very clear - you CANNOT attach this wheel without a hub, its not possible
Old Dec 3, 2008 | 05:39 PM
BLU CIVIC's Avatar
Track Advocate
looks good...saved some money too
Old Dec 3, 2008 | 06:32 PM
Radim's Avatar
That's pretty sweet, can you put in a quick release set-up on that aswell or is that hub already a quick release?
That Grant wheel isn't bad at all.
Old Dec 3, 2008 | 06:49 PM
Turbo Dan's Avatar
it is possible to add a quick release, although it adds a bit of length depending on what brand you use.
i sold my old quick release and right now i will be running without.
if you click the link in my first post you can see when i used a quick release to install it.
Old Dec 4, 2008 | 04:20 AM
Furyof4's Avatar
Very clean install. Thank you for posting.
Old Dec 4, 2008 | 11:25 AM
4DRmafia's Avatar
Nice, I'll keep this in mind if I ever wanted to do a itr steering wheel.
Old Dec 4, 2008 | 02:22 PM
ballin_tha_ef's Avatar
Pretty cool....whats the red thing in the passenger seat?
Old Dec 4, 2008 | 02:45 PM
schueytenten's Avatar
looks like a JDM rear spoiler
Old Dec 4, 2008 | 03:15 PM
89s1's Avatar
good eye, i agree that is what it looks like, and is.
Looks good man.
Old Dec 4, 2008 | 07:31 PM
WillieWillieFast's Avatar
Looks good.
Old Dec 5, 2008 | 07:59 AM
bquinn702's Avatar
very nice, not a fan of swaps but ya kept the H
Old Jan 16, 2009 | 11:21 AM
irev210's Avatar
Default Re: how to - install ITR wheel - MY way
does anyone know if you can use a momo hub?
Old Jan 16, 2009 | 11:55 AM
hushypushy's Avatar
Why wouldn't it? It goes onto DC splines, doesn't it?
As far as I know, DC splines = EG splines. And I bought the Honda Access Momo EG wheel (this one, mine has the cover on it though) which comes with a Momo hub for EG/DC. It fit directly onto my EF hub with no modification whatsoever.
HOWEVER--I do not have turn signal return, I have to do that manually. I really couldn't care less though, everything else in the car is manually operated anyway, besides the sunroof.
Old Jan 16, 2009 | 02:38 PM
Turbo Dan's Avatar
here is all you need to know in simple terms:
i didn't want to ghetto rig the stock ITR hub like you did
i didnt want to lose my turn signals like you did
sure it fits, but it doesnt WORK
i wanted a hub that both fit and worked!
so now enough with the odd questions, this is not a complicated idea.
so i have a nice looking nrg short hub, and i have my factory turn signal working properly, and i dont have the wheel tightened dangerously on only a few threads, its tightened properly with tons of threads.
the "however" part the reason for this thread, in the end i didn't want to have one single however!
cannot believe how complicated people make things...
some of the posts above didnt even think i needed a hub at all, they thought the itr wheel alone fit on the car with no hub at all.
Old Jan 16, 2009 | 02:42 PM
Turbo Dan's Avatar
click this link
https://honda-tech.com/forums/showthread.php?t=1953144
the answer is yes, you can but you need to drill and thread two extra holes because the pattern is a 4 bolt rather than a 6 bolt.
next time read the entire post! haha
thanks! and this wasnt even really a swap for me since the car never came with the stock wheel when i bought it, so i actually installed a wheel that was going backwards in the swap sense.
Old Jan 16, 2009 | 03:40 PM
hushypushy's Avatar
Ghetto rig? I just put the on the splines and lined it up. If that's not how you install any hub, then I am really confused
My turn signals work, btw, it's just the auto-return that doesn't. It appears that, in the end, you put all that work and effort so you could have...turn signal auto-return? Whatever floats your boat
Old Jan 16, 2009 | 05:50 PM
Turbo Dan's Avatar
post a picture of the bolt fully tightened on the hub, then we will see how clean of an install you claim it is.
and the signal thing, you're right i did put the effort in, you did the lazy **** most people do and now because of it you have to cancel your own signal.
n/m ill post the pictures for you
ghetto rigged itr hub with no signal cancel
fully threaded nrg hub with working signals
Old May 7, 2009 | 07:33 PM
hushypushy's Avatar
Who said not having a turn signal cancel is a bad thing? Not I
Old May 7, 2009 | 07:44 PM
jhammond_82's Avatar
Reject Papi
looks good in there!
Old Dec 22, 2009 | 11:49 AM
dr_latino999's Avatar
I'm bringing this back up because I just installed my wheel today, and TurboDan is right. Even with removing the turn signal canceler the overall amount of thread left is marginal. Yes the steering wheel does bolt on, no I don't feel that it is going to fall off, but I do feel that the Good engineers of Honda gave us xxx mm of thread to be used for a reason.
