Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
What do you think of these reported problems
Old Dec 3, 2008 | 05:02 PM
ajpturbopittsburgh's Avatar
Default What do you think of these reported problems
I just bought a 2001 ex sedan with a stick. It has 103,000 miles. Has anyone experienced either of these two problems or anything else with this car that would be helpful to know about.
An occasional problem on this vehicle is the failure of the Evaporative (EVAP) Canister Vent Solenoid that is part of the Emission Controls. This problem can cause the Check Engine Light to illuminate. The cost to replace the EVAP Canister Vent Solenoid is estimated at $49.33 and $32.50 for labor. All prices are estimates based on $65.00 per flat rate hour and do not include diagnostic time or any applicable sales tax
An occasional problem on this vehicle is the failure of the Driver's Door Switch and Headlamp Switch. Failure of the Driver's Door Switch may cause the Key Reminder System and the Dome Light to operate incorrectly. Failure of the Headlamp Switch may cause the headlamps to operate incorrectly. The cost to replace the Driver's Door Switch is estimated at $3.43 for parts and $26.00 for labor. The cost to replace the Headlamp Switch is estimated at $34.98 for parts and $39.00 for labor. All prices are estimates based on $65.00 per flat rate hour and do not include diagnostic time or any applicable sales tax
Old Dec 4, 2008 | 09:45 AM
texasnick's Avatar
I haven't had any issues with that.....I have an 04 with 93,000 miles, and the only real problem I have had is a busted window regulator.
Old Dec 4, 2008 | 10:34 AM
Ben850's Avatar
no problems here, '02 em2 with 119K
Old Dec 17, 2008 | 06:06 PM
Targa250R's Avatar
be professional
I've seen both problems on cars that we service, but neither is particularly common.
The most common issues on '01 Civics are broken front lower control arm bushings and blown front struts.
Old Dec 17, 2008 | 06:14 PM
ejLday's Avatar
door actuaters are known to go out, as for the rest I have not encountered yet
bigsnorlax
Apr 18, 2017 11:45 AM
socialistic
Nov 6, 2015 03:42 AM
crv007
Honda CR-V & Element
Feb 22, 2014 07:55 AM
Built B16A
Aug 14, 2004 01:06 PM
fishie
Sep 19, 2002 06:20 AM
