do ITR cams need ITR LMA's
Old Dec 3, 2008 | 02:26 PM
irishflame27's Avatar
Default do ITR cams need ITR LMA's
do ITR cams need ITR LMA's. i have never seen these replaced when doing so, but just want to be safe
*i have supertech valvetrain, and a b16a head*
thanks
Old Dec 3, 2008 | 02:49 PM
Death_to_Thieves's Avatar
no
Old Dec 3, 2008 | 04:33 PM
xsi-t's Avatar
yea u must use the same LMA's or your flux capacitor will no ignite in the right sequence lol j/k ...nope not needed
Old Dec 3, 2008 | 05:06 PM
b20beast83's Avatar
no but u need itr muffler bearings
Old Dec 3, 2008 | 07:37 PM
then why is there all this talk on the web that if u have a gen 1 b16 head (88-91.... I have a 91) that the LMA's need to be replaced because they have a small surface area..... any truth or all b/s!
Old Dec 3, 2008 | 11:25 PM
riceball777's Avatar
there are 2 lma's
the first gen b16 heads/ obd0 b16's/ 89-91 came with lms that have a much smaller surface area. all b16/gsr/itr heads after the jdm first gen came with the same new larger lma's
Old Dec 4, 2008 | 04:59 AM
sonicivic's Avatar
type r lmas are different they have a higher spring rate if you will, i have ctr cams and i researched this for a while on here and other sites and talked with my tuner about it, and came to the conclusion that i needed the type r or h22 lma mod. i did the latter, 70 bux in the whole shebang
to the op pm me i will sell you my gsr lma cheap
Old Dec 4, 2008 | 07:55 AM
taking from evans-tuning:
poster: i read that since the ITR cams have a higher lift, ITR lost motions have to be used.
jeff evans:
That is not true at all. The only real issue is on super large lift cams that the LMA has enough surface area so that the rocker doesnt slip off of it. The GSR and H22a have larger "pads" or surface area on the faces. ITR cams are not that large, and you dont really need to worry about upgrading the LMAs.
poster:does this hold true even for the gen 1 (88-91) b16a heads? i have been researching this myself and it says they must be replaced... i sure hope not lol i just finished my head
jeff evans: ihave tuned so many turbo cars with ITR and larger cams that have thrown together heads over the years that if it did matter I am sure I would have had a failure due to LMAs on the dyno by now.
Old Dec 4, 2008 | 08:00 AM
06sik20z3's Avatar
i have type r cams and did the h22 lma trick yesterday. everything is perfect.
Old Dec 4, 2008 | 09:26 AM
isnt the LMA only being used when VTEC is not engaged? so why would it be an issue during the event of high lift (like vtec)
SiRstewart99
Nov 13, 2012 10:28 AM
SiRkid
Jun 16, 2009 12:26 PM
mike_paz17
May 23, 2007 07:37 PM
1badda
Apr 28, 2006 06:25 PM
JDMGSRCRX
Dec 13, 2002 06:06 PM
