Climate Control Dash Options
Old Dec 3, 2008 | 02:05 PM
zachvirus's Avatar
Default Climate Control Dash Options
what are all of the climate control units that could be retrofitted into the crx dash?
i've heard that the 90-93 Accords and 92-95 civics could, but i believe those models dont use the cables for the heater vents.and any wiring schematic?
Old Dec 3, 2008 | 03:41 PM
dohccrxsi's Avatar
Your post is extremely non-specific, if you are asking about the vent control on either civic or accord controls into a crx dash, clearly you either have a civic or do not understand how the crx climate control works (88-91, the vents are electronically driven in a crx, the civic's are not, crx uses buttons to open and close, civic uses a sliding selector switch with a cable).
I have not done an EG CC swap yet, But the Accord CC uses the same system the crx does for vent control.
My advice to you would be to use the search function on here, I did the accord climate control swap into one of my crx' not even a week ago and it works flawlessly and 99.9% of the information I obtained to do the swap came from the search engine on this site.
Or you could wait around for somebody to start flaming on you....
Old Dec 3, 2008 | 10:02 PM
SilverCrx89si's Avatar
Default e-bay
search for crx climate control on e-bay. There is a guy down south that will sell you one with harness for around a hundred. Good Luck
Old Dec 3, 2008 | 10:08 PM
pandarex's Avatar
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/accord-climate-control-swap-crx-1434022/
here some stuff with no pics. FAQ
Old Dec 4, 2008 | 11:01 AM
detuned's Avatar
search it, it's on here somewhere. i used the schematic someone tossed up and wired my own up into my CF delete plate with toggle switches.
GPC91
Aug 9, 2012 11:09 AM
Silver93t
Jan 19, 2012 08:57 AM
iNetForce
Jan 21, 2011 03:02 PM
m2theizzy
Aug 4, 2010 07:02 AM
KDvtec5757
May 19, 2009 07:20 PM
