Dizzy question?
I was just wondering if the h22a and the h23 dizzys are interchangable... I just got a jdm f22b SOHC and i need to change the dizzy and i dont know what one works? Thanks for any help!
What type of coil setup is your wiring harness, internal or external coil. It would probably be easier to find a dizzy that matches your current wiring.
The JDM F22B SOHC will most likely be better off with an OBD1 F22B1 or B2 distributor.
B1 is a Hitachi dizzy with an internal coil and the B2 uses the TEC dizzy with an external coil.
FYI The H22A1 and H23A1 use a TEC dizzy and are the same part number 30100-P14-A01
So to answer your question yes the H22 and H23 dist. are interchangeable.
94 Accord...OBD1 i dont have a f22b2 dizzy i got to buy 1. I had a h22 in the accord but it was automatic and the tranny started to slip so i wanted to replace it with a stock motor. Thats why i asked if i can use the dizzy off the h22a
http://shopping.aol.com/1994-1995-ho...arch&id=9575ve
No problem,
The CKP is the Crankshaft Position Sensor. It is used to determine the timing for the fuel injection and ignition, it also detects the engines speed.
That link you posted only takes me to the AOL home page. It tells me there was an error.
The distributor you are looking for is for a 94 Accord F22B2 Honda part number is 30100-P0J-A01. If the seller doesn't have the Honda part number then the TEC distributor number is TD-59U.
Greenflashlight
Apr 7, 2012 07:24 AM
ASUJA
Jun 4, 2008 07:12 PM
ionic_slim
May 24, 2004 06:37 AM
1994, 94, distributor, distributors, dizzy, f22b1, f22b1f22b2, f22b2, hitachi, honda, interchangble, swap, td59u, tec, tech, work
