Weird starting problem
I have a 94 accord that I recently swapped from automatic to 5spd. To my knowledge I did everything correctly but when I go to start the car nothing happens. The radio, interior lights and windows won't function but the door locks work. Could this possibly be a relay?
Thanks in advance!
Thanks in advance!
what do u mean like the clutch safety switch? i didnt get the clutch one i bipassed it i am pretty sure that all the wiring is right but the problem is the it wont start it wont let my cdplayer turn on or let my windows go down... i just got a new battery new starter the alternator was replaced a couple months ago so everything is pretty new .... but the car its self had a security thing like i had to push a button then start the car for it to work but that was disabled by a local mechanic and it worked after that so i figured i could remove it so it could be that but if it was disabled already then why would it be messed up when i actually removed it... its just weird and doesnt make sense to me at all?
If this security system had either a Starter Kill or Remote Start functionality there may still be a relay or module lurking from that system which is playing games with you.
Did he remove the system or just disable it?
P
P
h disabled it and i removd the little box and stuff it wasnt a remote start or nething along those lines it didnteven have an alarm it was weird like u had to push a button in to make the car start and if u didnt push it in it wouldnt even click over which is kinda what it is doing now but i never thought to look for a relay or a fuse... someone from honda did disable it though but i know it wasnt removed at all and i already threw it away lol my luck.... thank you im going to look for a fuse or something today i know it was a honda security thing so maybe if i call honda and ask how to get rid of it theyll have a way
Honda OEM systems do not have this functionality (switch) (I believe)
P
ok i went out couldnt find a fuse or ne thing i did find out that the security thing was a chapman security system and i removed it all... it was completely disabled and now im stuck again... the windows still dont go down and the radio still wont start i did the wiring right and i checked every fuse i looked at the wire diagrams like 500 times and went over what i did so many and what i have done is correct.. i have no idea now what it could be do you know ne were that the relay could be sitting or ne thing
dontlooknow
Jun 3, 2008 02:06 PM
