Grease
Old Dec 3, 2008 | 01:43 AM
journeyquest's Avatar
Default Grease
do the 90 crx have grease fittings for steering / suspension? thanks
Old Dec 3, 2008 | 01:22 PM
snowseeker's Avatar
no
Old Dec 3, 2008 | 03:36 PM
EFRue57's Avatar
Originally Posted by snowseeker
no
x2
Old Dec 3, 2008 | 05:11 PM
The_Honda_Guy's Avatar
Most cars have not used grease fittings for a long time. Basically from what I recall, almost any car that uses a rack and pinion steering has not had grease fittings. The only times you'll see grease fittings on a car is generally the upper ball joints on double-wishbone cars. Some of the time though aftermarket replacement parts come with grease fittings though.
Old Dec 3, 2008 | 05:20 PM
Maireeka's Avatar
most trucks have a few, some 4x4s have as many as 12-15
Old Dec 3, 2008 | 05:25 PM
Right on. Usually trucks will have grease fittings for the upper ball joints at the least, more if they were a linkage-type steering instead of a rack and pinion. Usually any vehicle that used a linkage-type steering with a steering box had a grease fitting for each linkage and arm. This is why 4x4 vehicles have so many. Also, some of the older vehicles had grease fittings for the slip yokes on the driveshafts.
Assassinxiv
Suspension & Brakes
May 13, 2013 02:45 PM
Mohsin
Oct 7, 2008 01:56 PM
dr_latino999
Jun 17, 2008 09:59 AM
NZDelsoldude
Dec 15, 2006 02:30 PM
