Testing Waters: Fully Built TypeR Swap for sale!! (WI)
I am going back to school soon and I could free up some money so I am putting my fully built Type R swap up for sale. The motor was Built by REDZONE Fremont, CA . $6500 Not much room for negotiation.
jdm itr ss header
Hondata S300
2000 B18c5 Block (New from Acura)
Golden Eagle HD Sleeves
85MM 11.5:1 Wiseco Pistons
Eagle Rods
Spoon B18c Crank
ACL Standard Bearings
Moroso Street Oil Pan
RC 550cc Injectors
Golden Eagle 85mm Head Gasket
2000 B18c5 Head
Portflow Port and Polish (Very nice)
Bronze Valve Guides
Supertech High Compression Coated Valves
Supertech Retainers
Skunk2 70mm Throttle Body
Skunk2 Pro Series Intake Manifold
Skunk2 Pro Series Dual Valve Springs
SKunk2 Pro Series Pro2 Cams
Skunk2 Pro Series Cam Gears
Skunk2 Pro Series Cam Seal
Skunk2 Pro Series Vtec Solenoid Cover
new Distributer Cap
new coil
Toda Timing Belt
oem Oil Cap
Trust Oil Cooler
Z10 Block Fittings
2000 B16 Trans OBX LSD
Comptech 6LB Flywheel
ACT6 Puck Unsprung Clutch
Compression Tested at 270-280 across the board.
203 WHP 140 WTQ. With lots more room for improvement!!
jdm itr ss header
Hondata S300
Eagle Rods
Spoon B18c Crank
RC 550cc Injectors
2000 B18c5 Head
Bronze Valve Guides
Supertech Retainers
new Distributer Cap
new coil
Toda Timing Belt
oem Oil Cap
Trust Oil Cooler
Z10 Block Fittings
