Rim painting help
Old Dec 2, 2008 | 02:19 PM
spens 91 Ef's Avatar
Icon2 Rim painting help
i just picked up some rims for $80 the paint on the rims is pealing off need some ideas about repainting them. i need help with the sand paper or something to get the paint off, also what kind of paint and how many coats thinking about going with the same color silver that there already painted with or something close to it
Old Dec 2, 2008 | 03:45 PM
octaneaccord02's Avatar
Aircraft stipper and send it to a powercoating shop for proper painting.
Cheap way how I would do it not caring is aircraft stipper, 120grid sand start, primier, and paint.
Old Dec 3, 2008 | 01:49 PM
alrite what type of paint anykind of spray paint or a special kind how much is powercoating
Old Dec 3, 2008 | 04:53 PM
civichatch1999's Avatar
I would start with 80 grit move up to 180, then up to 320. You than can spray primer wait about 10 min after spraying the primer then spray your top coat and then clear or let the primer dry and wet sand with 600 grit and then spray your top coat and then clear
Old Feb 21, 2009 | 04:26 PM
S A D A N's Avatar
Default Re: Rim painting help
yeah when i painted my rims on my si.. i cleaned them really good laid primer on them and after sprayed just one coat on them they stood for long time.. i used the engine painting 500degree so it wont peel off in the sun..
greasmanky
Dec 4, 2005 08:39 AM
SiB16A
Feb 25, 2005 10:38 PM
sniperslayer
Nov 10, 2004 10:11 AM
zer0zer0 TypeR
May 29, 2002 07:28 AM
PurpleGsR00
May 28, 2002 12:59 AM
