tire rubbing and hitting weld
Old Dec 2, 2008 | 01:11 PM
royalrebel's Avatar
Default tire rubbing and hitting weld
currently im running 205/45/16 with 45 offset. and im lowered about 2 inches front and back with coilovers. when i make u turns the inner side of the tire hits the sidewall and eats away my tire. ALSO when i make hard left/right turns the pinch weld(metal piece right above the tire that sticks out) hits the tire dead on and shaves my tread away. any suggestions without raising my car??
Old Dec 2, 2008 | 01:43 PM
chargeR's Avatar
A friend of mine got a decent sized hammer and belted that seam up flat against the chassis then sprayed it with some primer and paint to stop rust. What car is this on by the way?
My tyres rub on the inner guard/chassis on full lock turns. I just ignore it.
Old Dec 2, 2008 | 02:30 PM
Mr.OB*GYN_Rhett's Avatar
Yes, you have to get an angle grinder/cutting wheel and cut that body seam in a couple sections and hammer it flat, as chargeR said.
Old Dec 2, 2008 | 04:31 PM
TunerN00b's Avatar
Sounds like you're running incorrectly sized tires and possibly wheels with the wrong offset.
The specific car isn't mentioned, but every Honda I've seen will put the UCA into the shock tower about the same time the tire will contact that seam (mine certainly does, dented shock towers too).
Is this a pre-96 Civic? If so, you should be using 205/40-16s.
If you're rubbing before full lock, then you probably have the wrong offset wheels on the car. Lowered to flushed rims and the mud flaps touching the ground, I can still turn the steering wheel lock to lock with the stock wheels (which I miss, damn thieves), but can't do so with my 16x7 5Zigens since the offset is incorrect (they rub).
Old Dec 2, 2008 | 04:58 PM
royalrebel's Avatar
its a 00 civic hatch. and no i only rub on the sidewall on full lock turns.
Old Dec 3, 2008 | 10:05 AM
nsxtasy's Avatar
H-T Order of Merit
That tire size should work on your car. It's more likely the offset that's causing the problem, or possibly the offset in combination with the lowering. Just lowering the car 2 inches probably wouldn't cause rubbing all by itself.
Old Dec 3, 2008 | 09:53 PM
royalrebel's Avatar
my bad i didnt even realize i typed a 2. I meant 3. My car is lowered 3 inches plus weight of driver and passenger when turning. so its pretty low.. anyone else??
Old Dec 3, 2008 | 11:50 PM
pinks11's Avatar
raise your car up a half inch or an inch. 3 inches is a pretty big drop. This is why you said earlier that your ride is bumpy, its caused by the shocks bottoming out every time you hit a bump.
This is Louis btw, the dude from subway.
Old Dec 4, 2008 | 05:34 AM
PACO(RRZ)'s Avatar
Ur tires might just be too big for ur car and/or your fenders might not be original .....i have a 99 ex coupe dropped on just coil over springs and on the side of my original fender it doesnt rub and on the aftermarket side it does
Old Dec 4, 2008 | 09:05 AM
royalrebel's Avatar
whats up Louis, yeah im planning on raising it a bit..its too low and too bumpy for a dd. Ill let you know how it turns out when its done.
team714
Jun 4, 2008 10:42 AM
^AnDre^
May 1, 2007 06:39 AM
Shmaa
Jun 2, 2006 02:48 PM
xstalkrx
Apr 7, 2003 02:17 AM
