Performance General Performance oriented Parts (Ex: Camshafts, Electronics, Air Intakes, Exhausts, complete engines)
AEM UEGO & Gauge Pod Combo: $220!!!
Old Dec 2, 2008 | 10:31 AM
National Speed's Avatar
Banned
Default AEM UEGO & Gauge Pod Combo: $220!!!
Purchase the gauge pod of your choice (one or two pod) for $220
And get an AEM UEGO Wideband for FREE
Click here to order now:
Store.NationalSpeedInc.com
A wideband UEGO sensor controller accurately monitors Air/Fuel ratios (AFR) during the tuning process to prevent a lean fuel mixture, which could lead to engine damage. AEM has combined its single-channel wideband UEGO controller and gauge display into one unit, uniting unsurpassed AFR accuracy and control with an easy-to-read interface. AEM’s Gauge-Type Wideband UEGO Controller features a digital LED display and sweeping LED “needle” that changes colors as AFR changes from rich to lean. The unit’s 52mm (2-1/16”) gauge housing fits in most gauge pods and can be remotely mounted virtually anywhere.
* Ideal AFR monitoring tool for EFI and carbureted applications, and engine dynamometers
* Does not oscillate AFR reading like narrow band sensors
* No laptop required for monitoring!
* Bosch sensor included
* Accurate to 0.1 AFR
* Reads in AFR or Lambda via a switch in back of gauge housing
* 24 Color-coded LED display lights provide immediate reference to engine’s air/fuel ratio (AFR) or Lambda ratio
* Integrated three-digit display reveals AFR or Lambda in real time
* User-programmable 0-5v analog output included for use with data loggers and virtually any engine management system
* Serial data stream included for output of AFR (RS 232)
Old Dec 8, 2008 | 09:47 AM
Banned
Take advantage of this deal while you can!
Old Dec 10, 2008 | 12:14 PM
Banned
Buy yourself a nice wideband/gauge pod combo for Christmas!
Old Dec 19, 2008 | 10:19 AM
Banned
This deal is still available!
phearable
Jan 9, 2008 03:23 AM
phearable
74
Oct 16, 2007 05:33 PM
mtber
26
Jul 20, 2007 09:49 PM
mtber
Jul 18, 2007 04:09 PM
