Any suggestions???
Hello everyone i have a favor to ask to all of you...i was wondering if u guys can give me all the suggestions and tips.
I have a k20A3 w/ tranny(si hactback) engine and im trying to drop it on a crx.
My Questions
Is it worth it???
Does is cost alot of money???
Would it pass smog???
Do i really have to make a hole on my hood???
What are the parts do i still need???
My Questions
Is it worth it???
do you have an ecu, harness, or a header?
you will need
-motor mounts: 750$
http://hasport.com/shop/product_info...roducts_id=125
-axles: start at 350$
http://hasport.com/shop/product_info...af15cbeaa759d4
-shifter mount bracket? : not sure if its exactly needed, or if there is one out there for an ef but just trying to give you an idea of what you are dealing with
http://passwordjdm.com/Karcepts-Shif...P2478C423.aspx
there is other stuff you will need, and the prices i listed above are the ones i just pulled from the links
you will need
-motor mounts: 750$
depends on how big your bank roll is. since you already have the swap i would say yes. however the hp sucks on that so you might condiser selling that swap, then saving a little extra to get a k20a2.
you're still gonna drop a couple of grand on it even with you already having the swap. so again, depends on how big your bank roll is and what you consider "a lot of money".
if done correctly.
not if you get a jdm front or SiR style hood.
Check the FAQ's. everything you need to know is in there.
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/crx-k-swap-walkthrough-1853644/
if done correctly.
