Why wont my car STAY 'started'
Old Dec 2, 2008 | 06:34 AM
Jonesy69's Avatar
Icon6 Why wont my car STAY 'started'
Ok, heres the deal.
Had the following symptoms.
Driving home from FT. Myers over the weekend on I-4 the dash board 'flickered' while the gauges shot from zero to my current speed and back rapidly. It did this for a few seconds, then resumed normal operation.
Today, I drove up to Walgreens from work and returned to start my car to no avail.
I can start the car, it gets up, and runs, I can let the clutch out, and as long as I were to leave the key turned forward, the car would run fine dash lights, sunroof, windows and all. But as soon as I let the key back it dies and there is no sunroof, windows, or dash lights.
Main relay? Bad contact somewhere? What do you all think?
Thanks,
Jonesy
My car, 1995 VTEC is having the following problems
Old Dec 2, 2008 | 07:37 AM
slamdlude's Avatar
http://www.hondaautomotiveparts.com/...INATION+SWITCH
You need #13.
Old Dec 3, 2008 | 03:49 AM
Jonesy69's Avatar
So basically a new ignition switch eh? Does it come with keys?
/noobish feeling
Plus I would go back and look for myself, but I'm on the worlds slowest dialup, and that site keeps timing out now.
Old Dec 3, 2008 | 04:13 AM
PirateMcFred's Avatar
It's just an electrical switch not the locking mechanism.
Old Dec 3, 2008 | 06:29 AM
red92si's Avatar
I just replaced the same thing. Its a piece of plastic with electrical connections that goes inside the ignition. I believe its part #110691.
Old Dec 3, 2008 | 09:09 AM
slamdlude's Avatar
Like pirate said: You don't need the keyed cylinder, you just need the "switch". It is just the electrical part that has gone bad. If you get the whole thing You will have two separate keys for your car unless you have the cylinder rekeyed. Unless you have been having trouble with your key turning I would suggest only getting the electrical part better known as the "switch".
Old Dec 3, 2008 | 12:26 PM
dark_rican's Avatar
I've changed 4 of these. Two for my ludes and two for friends... Get an ignition switch. No Key Tumbler..
Old Dec 4, 2008 | 06:34 PM
Fongman's Avatar
just replace the electrical part of the switch.
Old Dec 7, 2008 | 05:18 PM
jds06eagles's Avatar
so whats the difference between 12 and 13? (110691 or 110692?)
mr civicky
Apr 29, 2012 08:49 AM
Throwback23
Mar 18, 2011 06:52 PM
Mike36
Dec 11, 2006 08:03 PM
O16581724 5 2 5
12
Mar 10, 2006 05:03 AM
blo2k1
Mar 8, 2005 12:10 PM
