A/C evaporator gone... what about heater???
Okay, 1996 Civic. I took out my A/C system a long time ago from the engine bay. Today I just finally removed the evaporator so I could pull the fuse box harness into the car to mount it at the passenger kick panel. Since I don't have A/C, I don't want to put that heavy *** evaporator back in... but how am I supposed to connect the blower motor and heater unit back up, since the A/C evap connects inbetween the heater/blower assemblies to the air piping behind the climate control?
I'm assuming that the civic's that did NOT come with A/C must've had just a longer heater box... or did the 6th gen Civic's have A/C as a mandatory option?
Thanks!
Thanks!
Wow, you were dead on! I looked it... it's called an A/C delete duct for 96-00 Civics. I'm shopping for a good price now, but I'll call my local dealership too.
Thanks AK94GSR!!!!!!!
Make sure to check your local junkyard first. Any 96-00 Civic without A/C (although, these are rare in FL) will have it, and you should be able to get it very cheap.
yeah i took out my ac stuff in the engine bay but i wanted to finish it up under the dash... where can i get one for my ej1? or are they different from the ek? i tried to look them up onlione but i can only find the bypass valve, core, and motor...
TUR3Ovtec
37
Sep 17, 2010 05:11 PM
DrGrEeNtHuMb
Apr 25, 2008 09:49 AM
90 Si Hatch
Mar 24, 2005 01:54 PM
