Suspension & Brakes Theory, alignment, spring rates....
HELP! Putting Stock Spings back on
Old Dec 1, 2008 | 02:17 PM
MachAF's Avatar
Default HELP! Putting Stock Spings back on
I'm putting the stock springs back on my struts. I got the fronts done.
Now I'm having problems with the rear bolts. I broke one off already.
This seems like its a common problem (thank you salted roads). From the quick research I've done it seems the best way is to take the lower control arm off and not messed with the seized bolt on the strut.
Anyone have any suggestions how I should go about this?
97 GSR
Old Dec 1, 2008 | 05:45 PM
MachAF's Avatar
Update: I got the PAX rear side done by unbolting the control arm.
I'm not sure I should do the drivers side as the bolt head busted off, so there could be play in the strut.
So I guess drilling it out is my best option now?
Old Dec 1, 2008 | 06:39 PM
Tyson's Avatar
dont you plan on replacing that broken bolt? if its seized to the bushing, you need to replace the bushing too.
Old Dec 1, 2008 | 07:30 PM
MachAF's Avatar
Yes. I guess the best way is to drill it out or some how cut it off. No easy task with my limited tools on hand. Guess I'll have to buy some stuff.
Old Dec 1, 2008 | 08:40 PM
Tyson's Avatar
you should just order two new OEM lower control arms. they will come with 3 new bushings each and all pressed in, shiny and ready to go and last you another 10 years.
slo_hatch
Oct 14, 2008 07:48 PM
FuLlRaCe XLR8R
Suspension & Brakes
Feb 27, 2007 11:33 PM
Usdmowns
Sep 9, 2006 12:26 PM
thaimonkey
15
Jul 7, 2005 10:42 AM
user 98292739
Oct 20, 2004 06:20 PM
