91 accord
Old Dec 1, 2008 | 02:00 PM
honda1720's Avatar
Default 91 accord
hi i have the chance to buy a 91 honda accord ex 2 door with the automatic trans and 171000 miles on it for 1900 but ik where i wrecked 5 speed is i want to do the swap if i get it about how long do u think it will take with at 2 hours a day
Old Dec 1, 2008 | 02:20 PM
Brad_and_the_acc's Avatar
Swap what??? the trans? Depends on your skill level and your determination to get things done. I am still not clear on what it is your wanting to do. lol.
Old Dec 1, 2008 | 02:22 PM
honda1720's Avatar
Default 91 accord
ok the accord is in great shape i want to do a 5 speed swap out of a 92 accord that is wrecked and put a h22a in the car the car has 171000 is that worth buying for $1988 it is a 2 door
Old Dec 1, 2008 | 02:33 PM
The trans swap should`nt be a problem if the donor trans is in good shape and you know what your doing. A friend would be a good helping hand for a few steps of the swap.
2,000 for a car with 170,XXX on it is a little steep it seems but I dont have a clue to what condition the car is in currently. Maintenance records? Body of the car in good condition? Paint is good?, no chiping or clear coat pealing? Good looking motor? Motor "sounds" and seems to be ok? Is the car modded? Old or young previous Driver? Weather conditions on where the car is from?
There is ALOT that goes into buying a car if you care and are looking for the best deal. Think and inspect all these things. The last thing you want is to get stuck with a lemon, lol.
Old Dec 1, 2008 | 02:47 PM
honda1720's Avatar
Default honda
the accord has some clearcoat gone off the paint but i can get it done for like 25-50 on hood and the only rust spot is on the driver side back fender is starting to rust but no rips stains on seats at all and motor sounded ok do honda steering wheels vibrate when running ive always own domestic but my friend has a 92 accord lx
Old Dec 1, 2008 | 02:48 PM
honda1720's Avatar
btw it runns at like 700-1000 rpm is that normal
Old Dec 1, 2008 | 05:00 PM
P_Adams's Avatar
About 14 hours if it's just the Tranny swap*
About 18 Hours if it's the Tranny / Engine swap**
That's assuming you have a lift, an air compressor and any required special tools.
Why so much time?
Because, not only are you disassembling two cars, but you're assembling one as well.
You can't forget the console, shifter, shifter control cables, pedal hangers, Clutch Master cylinder and all it's plumbing. Among other stuff that escapes me just now....
If I were attempting something like this (and the '91 was drivable), I'd refresh the H22, install a new clutch of choice, mate the trans to it and install them as a unit.
That way, you'd have unfettered access to the engine compartment to run all the ancelary support stuff like swap harnesses etc.
The only thing I'd suggest: mark absolutely EVERYTHING.
P
oregonorganic76
Apr 26, 2011 05:52 AM
cb7slam
Feb 22, 2008 07:19 PM
dcskater56
May 14, 2007 08:47 AM
91accordhumper
Jul 29, 2004 03:36 PM
