is it true? 1000rr cbr 05
someone told me when poppin a wheelie on a 1000rr that it won't flip because when you past 46 degree angle the fuel cuts off.. is that true?
and is it ok to shift w/out the clutch? cuz he does it and i tried on my bike also and shifts just fine but was wondering if it's bad for the bike..
From: spinning DnB till your head explodes,jersey/philly
its fine to shift without the clutch if you know how to blip the throttle correctly. i only clutchless shift at full throttle by the way.
yes you can shift without using the clutch, but it will wear it out faster if you're not rolling off the throttle to put some slack in the driveline when shifting....but you have more important skills to master at this point (like not killing yourself).
good luck luvs2spooge, you're going to need it.
The only thing I can think of that resembles a fuel cutoff is the tipover sensor. Otherwise, that is the first I've ever heard of an anti-wheelie fuel cutoff.
I know Up On One uses a system like that for their wheelie-training machine. But theirs is aftermarket.
i dont do wheelies.. i try to ride safe.. to scared to do wheelies. just wondering if its true or not.. cuz he has 1000rr and told me this stuff.
btw how do you find your threads that you post in your profile? i hate this new way of ht. i miss the old way.
click on your user name top right
click on statistics
"find all threads started by..."
There is no fuel cutoff for doing a wheelie. Would you want the engine to cut off if you were going up a steep hill?
Even so a fuel cutoff won't necessary prevent your bike from flipping. If you did a wheelie real fast, you would need an angular momentum cutoff because stopping the engine won't stop the bike to continue "flipping"
