question bout my integra
Old Dec 1, 2008 | 12:18 PM
speed_unlimited's Avatar
Default question bout my integra
i'm having problems wit my integra i'm just tryna c if some1 out there can look out n help.
my car will start but it won't move when i give it gas or it a shut off, it idles lower than oem specs probably around 400 or somethn round there. i figured it was a clogged fuel filter so i changed that and the problem aint change. the fuel pump is good i can hear it i'm just tryna figure out where do i go from there cause i had my homie come look at it and he told me it could b my throtte body gasket so i'm on my way 2 change that now, but if ne boody got ne ideas plz let me know
thanks
speed unlimited
Old Dec 1, 2008 | 12:33 PM
mac_24_seven's Avatar
Dizzy may be going bad?
Did it just start doing this? If so, what were you doing when that happened? Is it smoking, burning oil, losing water?
More info.
Old Dec 1, 2008 | 12:51 PM
biggoofy's Avatar
did u check the idle screw
Old Dec 1, 2008 | 01:02 PM
If it was a leak at the TB, it would rev HIGH, not low. Air filter dirty maybe?
I read your first post wrong, I thought it was running bad all together, not just a low idle.
Sorry.
Old Dec 1, 2008 | 02:10 PM
biggoofy's Avatar
i belive i miss read as well but it might be set to low
Old Dec 1, 2008 | 03:02 PM
the idle screw is fine it seems like a vacuum leak cause when i start it, it barely sounds like its running, if it wasn't for the exhaust system u wouldn't b able 2 tell its started and i sprayed carb cleaner where the throttle body is around the gasket and it stumbled alittle
GaryTuesday
Jan 4, 2014 10:32 AM
DC4_teggy
Jul 10, 2009 02:34 PM
wanderinglost
Nov 7, 2008 08:31 AM
Rob Dizzle
Apr 23, 2003 02:51 PM
