Help just installed skunk2 cams on my gsr
please help, i intalled my skunk2 cams stage one with cam gears on my 2000 gsr, now it is slower. i checked my timing and it is fine. i advance the intake two degrees. my setup is i/h/e and FR. also im running on stock manifold and ecu. i know its slower cus i ran at the track my time was 15.7 compare to 15.4 without the cams. please help,thanks
i know its a type r area but i hope you guys i help.
when you get new cams you have to do some serious tunning, otherwise there was no point in getting cams. Most people still se some gains with the basemaps but not usually a lot. Get some cam gears , a vafc and book some tuning time.
Well you should not advance the cam unless you dyno to see what the correct setting should be.
[Modified by 401-2001, 10:50 PM 8/1/2002]
i only change the timing because skunk said advance the intake +2. and the timing belt i brung my car to a shop and they checked it with timing light and all and the timing id perfect. i guess i have to dyno
they'll adjust your timing, fuel setting, vtec engagement, etc.. ask for references for a good shop with a dyno that does tuning in your area, or request the help(with payment, of course) of someone from here that knows what they're doing in your area..
good luck with the skunks, and be sure to post your dyno plots..
At the moment, I also have the same problem with Stage 2's. Feels a lot slower, hopefull tuning can fix that.
Stage 2's need more than 10:1 CR that may also be your problem.
