Integra GSR ** code 67 ** Catalyst Efficiency Low - Bank 1
Old Dec 1, 2008 | 10:24 AM
LOVEthatDC2's Avatar
Default Integra GSR ** code 67 ** Catalyst Efficiency Low - Bank 1
So I plugged my car into my dads OBDII reader and it gives me a Catalyst Efficiency Low - Bank 1 ...
Just wondering what bank 1 means? I'm guessing it is one of the 02 sensors? Thanks!
Old Dec 2, 2008 | 10:06 AM
anyone?
Old Dec 2, 2008 | 10:19 AM
bakertime's Avatar
Sounds like either your secondary o2 is bad, or your cat is bad...get a second opinion though, I'm not 100%.
Old Dec 2, 2008 | 12:25 PM
thanks for the info ... hate clearing the CEL every 3 days haha
Old Dec 2, 2008 | 01:35 PM
bumpage
Old Dec 2, 2008 | 04:24 PM
HondaLove517's Avatar
all bank 1 means is which ever side cylinder number one is on. So on 4 cyl it means nothing but your primary cat. It's of more purpose on v6 and v8 since they have a y pipe and sometimes one cat for each side of the motor. So if it was a v8 and the cat opposite of one that it would read bank 2. There's all kinds of diff setups for cats but that's the general
Now to answer the second part is the code means that 95% chance your cat is bad. Replace the cat and clear the code. If you have a sencodary o2 (after) the cat and the light comes back than replace that sensor, probably wouldn't hurt anyway. Now be careful because if you replace the cat with an aftermarket (universal) cat sometimes they're no good and the same code with come back
So in end, replace your only cat you have first. If light co we back for the same replace that sensor. In the rare case after all that and the light comes again, replace the cat again cause it's no good. Hope this helps.
Old Dec 3, 2008 | 08:27 AM
sounds good, thanks for clarifying ... I'll give that a try. Maybe I can find someone that is selling a cat now ... new ones are ridiculously overpriced
sidoe
Nov 1, 2008 02:38 PM
elpiar
May 8, 2005 09:37 AM
Two_K Si
Oct 13, 2004 08:32 PM
DelsolVtec18
Sep 4, 2001 11:51 PM
