about to crazy glue brake pad shims!
Old Dec 1, 2008 | 10:03 AM
HonDA INTEGRATY's Avatar
Icon2 about to crazy glue brake pad shims!
so I ****ing bought these 'duralast' (built to fail ****ing autozone) brakee pads and the first pair had the shims put on already but they kept coming off when I clipped them inside the caliper...then I returned them and the second pair like had an adhesive strip and you put them on and bent the little flaps over...yeah well the same ****ing thing happened...the only thing I can think of is if i crazy glue them the heat from the brakes will melt the glue but wouldn't it do the same for the adhesive that doesn't adhere anyways!
should I just return them and get better pads! Help!
Old Dec 3, 2008 | 05:12 AM
dc2moi's Avatar
nah use, some of the caliper grease, apply a small amount, and then apply the caliper, i just recently had that same problem when working on my integra. give it a try! it worked for me
Old Dec 3, 2008 | 05:56 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
tha hell? I've been using AutoZone pads for years now, and they NEVER come with shims. I've just been swapping the original OEM brake pad shims over from pad to pad and never had a problem.
Except the last time I forgot to remove the shims from the old pads when swapping them out under warranty, so I have no shims now on my rear pads. on me.
Old Dec 3, 2008 | 07:47 AM
CompanyFlow's Avatar
Eww you use Autzone pads?
Old Dec 3, 2008 | 09:37 AM
Community Builder
ummm yes and the car stops just fine thanks. When they wear out, I get another set for free since they have a lifetime warranty (for whatever reason, oh well). I haven't paid for a set of brake pads in over 6 years and 150K+ miles.
Old Dec 4, 2008 | 07:18 PM
mayoforlife2's Avatar
i hate shims, iv stopped using them, iv seen on customers car where they fell off the pad, and actually cut the whole front of the rotor off from rubbing against it.
Old Dec 4, 2008 | 07:39 PM
super jdm yo's Avatar
now that's a deal regardless the brand. just get one of those brake grease stick it on.
Old Dec 5, 2008 | 03:33 AM
non-VTEC's Avatar
if you bend the tabs hard enough they will snap/lock onto the pad and wont move.
Old Dec 5, 2008 | 03:55 AM
OvernightPartsFromOZ's Avatar
Honestly, your first problem was buying duralast pads for the Acura. Give your car a little more love than that.
Old Dec 5, 2008 | 05:51 AM
Community Builder
Please explain how using AutoZone pads is somehow less "good" for the car than other pads? The car stops every bit as good as it did from the factory.
I can't stand how people hate on certain parts simply because of the name that's on them. If they work well, have a good price, and are readily available locally, then what the hell is the problem?
Old Dec 5, 2008 | 07:22 AM
Duralast is typically a poor brand, that is all. I'd much rather use OE, or Hawk pads, and therefore only use that stuff on mine. I guess i usually look for quality over cheapness. Just a preference thing.
cyclonedr
Mar 27, 2010 10:03 PM
SkaiWu
Dec 6, 2008 05:12 PM
h8ted ek
Aug 26, 2008 04:18 AM
Nishant
Jun 12, 2006 09:39 AM
mingbling96
Jan 9, 2005 06:09 PM
