voltage correct for rc 1000cc injectors?
Old Dec 1, 2008 | 08:03 AM
vtec-adykt's Avatar
Default voltage correct for rc 1000cc injectors?
im trying to idle my 1000cc injectors. is there a magic voltage number i need to dial in to get my car to idle correctly? im using s300 for tuning. right now it reads like this....
stock inj 240
current inj 1000
volts 0.00 8.09 10.11 12.13 14.16 16.08 24.55
dead time(ms) 1.49 1.49 0.96 0.68 0.49 0.35 0.35
Old Dec 1, 2008 | 08:07 AM
vtec-adykt's Avatar
fuel trim
overall fuel trim -27%
cranking fuel trim -15%
throttle tip in trim 0
cold start
post start fuel adjustment -10%
Old Dec 1, 2008 | 08:30 AM
HRTuning's Avatar
On top of trimming from 240 to 1000 you're pulling out an extra 27% as well. That's probably part of the problem.
Old Dec 1, 2008 | 11:02 AM
vtec-adykt's Avatar
so should i trim it by less percentage or should i type in 800cc or something?
Old Dec 1, 2008 | 12:40 PM
HRTuning's Avatar
The overall will probably need to be a positive number. You take the full linear trim out by going from 240 to 1000 and since the injector takes longer to open it will usually run a little lean. Start at 0 for overall and dial it in. Tune it.
rice a roni
Engine Management and Tuning
Apr 26, 2026 03:22 PM
inkong
Aug 17, 2007 06:05 AM
verizon521
Mar 12, 2007 09:21 PM
racinskittle
Jan 18, 2004 07:06 PM
