no prime/no spark/no start
Old Dec 1, 2008 | 07:53 AM
SoHc94's Avatar
Default no prime/no spark/no start
well.. heres the deal.
friend got a hack jobbed crx with a b16a in it. car ran fine.
turbo build we took it out for the rebuild. built it. put it back in.
went to start car.
heres what we get.
car will crank. over and over. no spark. the fuel pump does not prime. the cel stays on and doesnt turn off when u flip the key to the on position. his VAFC does not come on either. i hear a buzzing coming from his dash. 2 differnet styles.
i think in my head. relays. so i tell him to replace them and see if it works. he says he cant find them. as i dont know crxs very well. and cant get over there for a while. does anyone have any light to shed on this?
if no spark or prime. im correct in thinkin relayS? all the fuses are fine.
where exactly are these located..
Old Dec 1, 2008 | 11:41 AM
ef9_b20's Avatar
pm'd
Old Dec 1, 2008 | 11:47 AM
SOHCinWA's Avatar
Check the main relay
Old Dec 1, 2008 | 12:36 PM
SoHc94's Avatar
thanks ef9...
wow. sohc
ur a quick one. hence my question as to where the hell it is.
Old Dec 1, 2008 | 12:53 PM
ef9_b20's Avatar
no prob, no with it still connected, try to start and see if you can hear the relay click yo
Old Dec 1, 2008 | 01:06 PM
4drEF's Avatar
Keyboard Humorist
Seeing how you didn't mess with the wiring and only pulled stuff from under the hood, my guess is that you have something disconnected or miswired under the hood.
My guess is a ground wire.
Old Dec 1, 2008 | 02:00 PM
SoHc94's Avatar
ive done a few swaps. all the ground wires i no of are grounded.
tranny valve cover. battery. everything is hooked up. i guess we will try swapping the relay
Old Dec 8, 2008 | 12:14 AM
fishinfool88's Avatar
I'm in the exact situation. I resoldered the main relay, still no go.
Old Dec 8, 2008 | 12:20 AM
Nang's Avatar
one time i had the same problem ,but then i checked that one switch on the clutch pedal and it was cut soldered and my car started. try to check that
Old Dec 8, 2008 | 02:08 AM
FUSE #14 Alternator/Solenoid Fixed mine, maybe check it out
Old Dec 8, 2008 | 06:03 AM
SoHc94's Avatar
all fuses check out.. replaced that relay. still no go.. my friend was thinking autozone may have given him the wrong relay(wouldnt be the first time). but. were not sure.
Old Dec 8, 2008 | 07:42 AM
EFstyle's Avatar
you didnt list one of the most commonly overlooked grounds... take a look at the thermostat housing and see if the harness is grounded there.
Old Dec 8, 2008 | 08:24 AM
4drEF's Avatar
Keyboard Humorist
It may not be gorunds, but it really sounds like it is. It won't take long to wire up some alternate grounds just to prove it out. I would hook some jumper cables to the battery ground and clamp to the motor and chassis just to make sure.
olschool92
Jul 25, 2011 02:38 PM
gen2_4door
23
Mar 17, 2010 06:24 AM
bmxbikes
22
Jul 4, 2007 07:23 PM
shaved4dr
Oct 29, 2006 06:38 PM
.ShawnD.
Aug 31, 2002 02:57 PM
