motor shake!
Old Nov 30, 2008 | 11:04 PM
shake-zula's Avatar
Default motor shake!
i have a ek hatch.....jus put in a b20b, i also put in an innovative mount kit with both torque mounts too... and when im accelerating at 30 to 40mph feels like the motor shakes.... before 30mph doesnt shake and after 40mph doesnt shake only between 30 to 40.... sometimes its worse than other times....its to the point where its annoying....i just need good points to start at the half shaft has no play....the axles are rebuilt.....input welcome... thanks
Old Nov 30, 2008 | 11:41 PM
ABK's Avatar
ABK
I had problem with some autozone axles binding a while back and would shake under acceleration. might want to try to swap them out if you got some extra ones laying around.
Old Dec 1, 2008 | 03:47 AM
Hanmin's Avatar
does it shake regarding rpm or speed? if its rpm it could be because you have stiffer mounts. if by speed then its something after the transmission. axles, tires..
Old Dec 1, 2008 | 09:08 AM
shake-zula's Avatar
its always by speed......i could floor it in 1st then shift into 2nd and accelerate normal and itll start a 30mph.....im going to try and get my hands on some new axles
Old Dec 1, 2008 | 10:00 AM
instructor74's Avatar
Help!! Your english teacher is rolling over in her grave. I couldn't even find one complete sentance or thought
Old Dec 1, 2008 | 11:26 AM
kp's Avatar
kp
First of all, learn how to spell if you're going to critique someones post. Secondly, his posts were pretty straight forward, maybe you should learn how to read too.
Old Dec 1, 2008 | 12:49 PM
shake-zula's Avatar
i didnt know it was an english test... didnt want to write a book
Old Dec 1, 2008 | 01:36 PM
eskerley's Avatar
it kinda sounds like your tires or maybe your wheels are off balance. I locked my tires up and flat spots formed on my tires and at around the same speed it would shake. Just a thought.
Old Dec 1, 2008 | 01:46 PM
ABK's Avatar
ABK
yea it has to be a drivetrain issues because it only does it under load.
Old Dec 1, 2008 | 04:20 PM
instrument's Avatar
IF you can read this thank a teacher if you can read it in English thank a vet "
maybe you should go speak to a vet.
kenttouchthis
Aug 24, 2008 04:09 PM
crv-techu
Nov 24, 2007 08:36 PM
Turbo-Tec
21
Jun 17, 2005 06:31 PM
Coltrane
Feb 22, 2005 08:22 PM
civichbb18c
Oct 22, 2003 11:26 PM
