Chicago & Illinios FS/FT WTB December 2008
Inventory stuff for sale
JDM bling spark plug covers ( billet aluminum ), mad tight hooker points if you have these
ARP head studs ( Brandon will give you instructions on how to install them, and mac on bitches as well )
Walrbo fuel pumps, with or with out kits, Brandon will also show you the do and don't on installing these, you must provide him with a square though in order for him to demonstrate
JDM orange peepee corner lights
Rywire harnesses
Autometer pryometer gauge
Rywire harnesses
WTT clean ls mesh wheels. 1 rim has a little curbing, not bad. front tires are brand spankin new! rear are good, but have bad camber wear, been driving through all sorts of snow with no problem at all.
I got a BRAND NEW Bullseye Power/Borg Warner T4 S366 .83 AR turbo up for sale. These go for 1475+ brand new. Will come with extras such as, Drain Flange, V Band flange and clamp ( for Exh side) and the exhaust side has been thermal coated, compressor side has also been powder coated black. Pics available upon request.
Also have 2 S372R compressor covers, one polished and one with the original finish. Pm me for pricing if interested in anything. Thanks
some parts of my em1 and a ek.
stock ek wing white. good condition.
stock SI shift boot.
b series clear distrubtor cap with rotors.
ek passenger side window
99 ex seats front and rear
need sold. throw offers
WTB some kind of rear seats from a dc2, ls hydro tranny.
Buy or trade, i need $$
http://www.hondamarketplace.com/show....php?t=2440590
need gone asap!!!!!....Price drop!!!!...this week only for $375 FIRMMM!!!!!
http://www.hondamarketplace.com/show....php?t=2435449
This is not the complete kit. It is missing the blue box and injectors. What's in the pictures is what you are getting. The wastegate actuator I believe has a small leak. This was remedied for me by using a manual boost controller to avoid the vacuum leak. Otherwise you could find a new universal actuator from Jegs for under $100. It was boosting around 8-10 psi. No shaft play on the turbo. Any questions just ask. $550
If you can find me somebody to buy a disassembled B18B1 that needs cylinder re-bore, pistons, gaskets, and rod journals refinished on the crank, I'll take off another $50 from the turbo kit. Oil pan still has turbo oil return installed.
I might still have ARP headstuds. $200 for the engine.
94-00 Acura Integra, coupe, cargo cover. Black color. Price: SOLD
94-97 Acura Integra driver side head light. Price: SOLD
01-04 oem civic cd/radio. Price SOLD
If you don't like the price make an offer. I am located by Rockford, IL.
I am willing to meet up for a little gas money!
Items wanted in trade at bottom!
FS:
-Front Mount Intercooler 27x7x2.5 Brand New $125
-STR D series block guard $40
-EF front crossmember with stock front mount flattened for a B swap, has poly radius rod bushings installed. $30
-90 Civic DX front knuckles/brakes. Needs pads and rotors, not sure on condition of bearings since I never drove on em. $30
Will trade for:
-ARP d16z6/a6 head studs
-walbro 255 fuel pump
-90-91 si aftermarket clutch
-EF motor mount inserts
-D series Aftermarket Header
-Or other D series bolt-ons and D16 rebuild parts
-rear camber arms for EF
FS:
Will trade for:
