clutch not disengaging??? help
Old Nov 30, 2008 | 09:23 PM
boosted_b_delsol's Avatar
Default clutch not disengaging??? help
i have a 93 honda del sol s with an b18ls swap. i just recently swapped out stock clutch and flywhell for a stage three clutch and 7.5 lbs flywheel. the car drove fine for bout 3000 miles but now has a problem. occasionally the clutch will not disengage when i push the pedal to the floor but it only seems to happen when in first or second gear. my first thoughts were either a slave cylinder gone bad or a bad pressure plate but the clutch kit only has about 3000 miles on it..... if anyone has any ideas on what the prob could be i would greatly appreciate your input
Old Nov 30, 2008 | 09:29 PM
teamworxek9's Avatar
wouldnt be the first time i seen a pressure plate go bad. did you whip on it or work it in right?
blink_977
Jun 4, 2009 01:31 AM
marecco
Transmission & Drivetrain
Mar 17, 2009 07:50 AM
94accord718
Sep 10, 2007 01:22 PM
95frostwhite_integra
May 31, 2007 10:10 PM
Chris_R
Oct 4, 2005 10:10 PM
