98 Civic EX Coupe.:.Tire Stretch (search=no go)
Alright. Ive got a 98 Civic EX Coupe. Its white and as of now on stock suspension(Christmas looks promising towards teins). I picked up some cheap rims from a friend who totaled his EG. They are 17X7 white some black.
He curb rashed the ***** out of them so I decided to "repair" em. I sanded down the entire rim and worked my way up to about 800 grit so it was smooth. I decided to repaint them lime green for now (wanna be different) but I might go back to white.
Anyways...Im gonna need some new tires and I love the stretched look. They are 17X7's so I need a good tire size and brand for the stretch.
Also if anyone good recommend the right spacing I might need to make the tire loof flush with the fender line.
All comments/critique welcome. Thanks.
By the "stretched look", if you mean using skinny tires on wheels that are wider than approved by the tire manufacturer for that size, that is unsafe and a bad idea all around. But on those wheels, you can slap on some 205/40-17 tires and you'll be fine, with no problems at all (assuming that the offset is what you need for your car).
The range of approved rim widths for tires is explained on the Tire Rack website here.
Stretching the tires is something that is practiced alot on Vdubs but it is very unsafe... also most Honda guys don't do this because you cause to much stress on your tires which equals into a loss of performance!
You didn't mention the offset of those wheels. The offset number (when combined with the wheel width) determines the positioning of the face of the wheel, out from or in towards the car body. Look in the FAQ topic stickied at the top of this forum to see how offset is calculated. I don't know what offset works best on your car. In general, you want the wheel positioned for maximum clearance around the tire, so it doesn't rub anywhere. There are parts you can get to push the wheel out further - spacers, preferably hubcentric ones, possibly with extended studs and open-ended lug nuts - but you have to be careful that that doesn't cause the tires to rub on the fender liners.
I would suggest getting the 205/40-17 tires and mounting them on the wheels, and seeing how they look. They may look fine without doing anything else. Assuming you're not going for the low-rider look, of course.
And if not, then you can look into getting those additional parts.
Stickied at the top of this forum is a topic:
Forum Rules and FAQ - READ BEFORE POSTING
It says:
It says:
Originally Posted by Forum Rules and FAQ - READ BEFORE POSTING
Rules
7. Bump once and if you still don't get the info you're looking for just let it die, don't bump it again. If you bump the topic a second time, the topic will be locked and you will lose points.
=honda4life=
Nov 30, 2008 02:59 PM
ridin4jesus
33
Jul 11, 2006 08:27 AM
good choice!
