are 310cc injectors to big for my setup?
I have done the research but not had my questions answered.
I have a b16a and am installing skunk2 tuner stage 2 cams along with a full valve train. the head is getting a porting job as well. I have a skunk2 pro-series manifold, intake, header, exhaust, aem fuel regulator. stock short block. also i plan to put a 50 shot on in the future. are rc 310 injectors too big or are they good for my setup. thanks for the help.
dude tuning software is the most essential thing in the car man....not having it is like building a house on sand and expecting it to be sturdy....i have 310cc injectors on my b18c1 and its built and supercharged on 8 psi
i dont know bout that i have an obd2 ecu and im on a vafc which is horrible and most likely to blow my **** sky high....im going for a hondata s200 setup with boost option....what is your setup are you built, boosting, ?
Nope. BRE with an Ostrich and Hulog.
http://forum.pgmfi.org/
It ends up costing about as much as Hondata before the OBD1 swap.
...and it's Crome
...and it's Crome
Actually the VAFC isn't THAT bad. The only byproduct of it(can be positive or a negative depending on setup) is that it inherently changes timing by modifying the MAP signal. I've tuned a couple cars with VAFCs and gotten rock solid A/F ratios but who knows what the timing was at...
this is an all motor build. im not planning on boosting it. i am planning on nitrous in the near future. the guy porting my head said that with all the added airflow from the head and cams and manifold, that i wold have to upsize injectors. he also suggested a wideband 02 sensor to monitor it and hondata. my question is can i get away with the stock injectors or do i have to upsize and tune the comp?
stockers will be fine for now i would assume if you are running low on money, definantly get the hondata and the wideband before just about anything else
what fuel will you be running, 93 i would assume
if you were to run e-85 you would need bigger injectors
probably upgrade the ecu and get it socketed for hondata....you can buy a s100 setup with ecu for im guessing 200- 300 cause im looking at a pretuned s200 for 400
