Anything meant for a D16A6 but you'll have to port out the manifold to match. If my memory is right, the ports on each head are offset but the bolt pattern is the same.
Die grinder you can find from any tool company. Maybe a dremel too but would take a while. Just line up the gasket to the manifold and mark it. Then start grinding!
