Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
How to Launch???
Old Nov 30, 2008 | 10:28 AM
d[-_-]b FD2's Avatar
Default How to Launch???
So i went to race a little last night , and i had an issue. i couldent launch right .. so i was wondering .. where you guys all have your sweetspot ... i tried a little over 4k .. im running on yoko's and like 37psi
Old Nov 30, 2008 | 10:29 AM
oh .. just intake headers and exhaust is done to the car.. and second gear is a b**** to slam.. whats up with that?
Old Nov 30, 2008 | 10:31 AM
soupE__'s Avatar
Header*
Old Nov 30, 2008 | 10:50 AM
Header.
Old Nov 30, 2008 | 11:13 AM
203_EM2's Avatar
with vsa on i usually launch it around 3.5k and dont give it full throttle at first but with vsa on i usually launch it around 2.5-3k anything higher and it will spin all through first and you have to really rev out first so when you hit 2nd it stays in vtec or the car will bog on you
Old Nov 30, 2008 | 11:20 AM
EM2Civic's Avatar
If you got an Si watch out 2nd gear is a bit fragile.
Old Nov 30, 2008 | 05:41 PM
203_EM2's Avatar
thought it was 3rd and the 02 rsx trans was 2nd
Old Nov 30, 2008 | 06:08 PM
ajpturbopittsburgh's Avatar
I know these are SI's but these cars don't have that much power and they have limited slip diffs which helps out tremendously. Leave the vsa off. You don't want factory computer intervention. Usually with high horspower low torque cars there is no good way to launch with out slipping the clutch. 3k and agressively let off the clutch and floor it simultaneously. Ten feet of spinning or chirping while getting traction is good, That's what pros do. Watch Motorweek on speed channel.
Old Nov 30, 2008 | 06:14 PM
eg93LS's Avatar
if u launch about 4k then, befor u actually launch rev to 5 then right befor u start drop down to 4k and it will go harder then if u just held it at 4k, im not quite sure how, my friend explained it to me but i used to smoke alot and as u all know it makes u forget, any way it works and i just kinda floor it every gear after that, only cause i dont have to worry about spinning through 3rd gear, but i get a bark! lol
Old Dec 3, 2008 | 01:28 PM
100miles+'s Avatar
From: In Diamond Bar, CA Brake Boosting like a Mother Focker!
Turn VSA off, rev up to like 3-4 K and let off the clutch aggresively while flooring first and flat shifting trough 2 to 4 and after that you should be golden and just shift like regular.
Old Dec 3, 2008 | 06:42 PM
MugenManR's Avatar
idk if si are the same. but my mugen has something like 2step prob just a netural rev limiter but i use that. and careful with second, i broke a torque mount already and the car only has 7k on it
Old Dec 3, 2008 | 06:53 PM
What and where is the torque mount? What did it cost to fix? How did you break it?
Old Dec 4, 2008 | 01:22 PM
100miles+'s Avatar
Yea where is it exakkktly, never even heard of a torque mount?
Old Dec 4, 2008 | 03:19 PM
TRAG's Avatar
personal take...
ive experimented with all sorts of RPM ranges. from 2K all the way to about 5K.
My personal preference is like 3250 ish and just dumping the clutch..but like the others have said..2nd is a BITCH to catch now. I also screwed the hell outta my 3rd gear and just got it fixed threw the TSB.
With alot of these "launches" it may be best to 'feather' the cluth to get the "picture perfect" launch...its really how you get acquainted with your car and become comfortable/familiar with it..
long story short...for me 3250 and a little feather-ing
Old Dec 4, 2008 | 04:54 PM
2008fijibluesi's Avatar
^^ Exact advice that you should take.
Also, leave your tires at the OEM recommended PSI, unless you are running slicks or drag radials. For one, lowering the PSI doesn't help (believe me I've experimented like crazy). And two, many people don't realize that when you turn the VSA off (like you have to do to launch hard) AND lower your PSI too much, the VSA turns on anyway, defeating the purpose of both.
Old Dec 4, 2008 | 05:54 PM
i-VTEC_DOHC's Avatar
whats a torque mount??
or do u mean motor mount?
or do u mean the break away motor mount?
Old Dec 4, 2008 | 07:29 PM
K5^'s Avatar
K5^
Brand New
Does the VSA turn on in response to the TPMS indicating that the pres. may be too low? I didn't know that the VSA spontaneously kicked on under those conditions. As you can tell I don't drive that hard too often haha.
Old Dec 4, 2008 | 08:57 PM
yes.
Old Dec 4, 2008 | 11:28 PM
K5^'s Avatar
K5^
Brand New
Originally Posted by i-VTEC_DOHC
yes.
Makes sense.
Old Dec 5, 2008 | 10:06 AM
originalg00kster's Avatar
3500 feather power shift and you'll stay in vtec
Old Dec 5, 2008 | 10:28 AM
burnout8488's Avatar
It'll be a cold day in hell if I buy a used Honda.
bznc18
Oct 9, 2006 09:22 PM
geminis2k
Mar 5, 2003 07:33 AM
timberwulf
31
Oct 2, 2001 01:58 PM
