2000 Civic Si startin Problems
Old Nov 30, 2008 | 10:18 AM
Devious951's Avatar
Icon6 2000 Civic Si startin Problems
I have a EM1 and i tryed to change the Dis but i end puttin the old 1 back on. Doing that my car wont start anymore. I flipped it 180 and tryed to start it but nothin, i would put it to TDC and nothin, it cranks but doesnt start. It has spark but yet no start i checked timing and come to find out i jumped it, so i ended up changin the timing belt and setting timing to where its suppost to be but yet still no start.. HELP ME PLZ
Old Nov 30, 2008 | 10:47 AM
redline7070's Avatar
check the fireing order
Old Nov 30, 2008 | 01:31 PM
Devious951's Avatar
i did and its where it post to be...
Old Nov 30, 2008 | 01:47 PM
lluks_844's Avatar
You tried to start you car with it 180 degrees off?
If so im sorry to say thats how you bend valves. Ive seen it happen in my driveway.
Check the timing belt it may have jumped teeth.
Old Nov 30, 2008 | 01:49 PM
Devious951's Avatar
i did that like 5 different timez. I also set it to TDC like 4 timez. I have heard that Civics have been infamous for the Distributor and the ignition modual
Old Nov 30, 2008 | 03:43 PM
do you have fuel are the injectors pulseing ?
did you you have any cells ?
did you move any grounds
Old Nov 30, 2008 | 05:13 PM
K i l l a B e e.'s Avatar
how did you manage to start it at 180deg off?
Old Nov 30, 2008 | 05:20 PM
Devious951's Avatar
Everything work.. its gettin gas and spark.. i haven moved anything. And the way i managed that is when i took off the dis i was playin with it.. but when i try to start it you hear it crankin and you hear something through the intake
Old Nov 30, 2008 | 06:05 PM
is the cell cuming on then going off?
Old Nov 30, 2008 | 06:07 PM
lluks_844's Avatar
when you set it to top dead center. you looked at the timing belt and cam gears right? Was everything aligned?
Old Nov 30, 2008 | 06:08 PM
how did you put the dis 180 off? it only goes one way you may have f*** the key way on the end of the dis
Old Nov 30, 2008 | 06:09 PM
lluks_844's Avatar
It can be done that way which the end result is jumped timing.
Old Nov 30, 2008 | 06:15 PM
do a compression test you could have gas washed the rigs
Old Nov 30, 2008 | 06:51 PM
Devious951's Avatar
well when i did the timin belt i looked at everything to make sure it was on point and it doent want to start.. Im bout to do the Com test tomorrow, cuz i could have bent a valve right?
Old Nov 30, 2008 | 06:55 PM
lluks_844's Avatar
If you didnt jump timing, I dont think so. but you could
Old Nov 30, 2008 | 06:59 PM
put a good know ecm in
Old Dec 1, 2008 | 10:29 AM
Devious951's Avatar
and where should the compresion be at?
Old Dec 1, 2008 | 10:58 AM
vtecb18c's Avatar
in the mid 200's....anywhere from 210-250 is where its supposed to be for a b16
Old Dec 1, 2008 | 11:28 AM
Devious951's Avatar
How would i check if i fryed my ECU?
Old Dec 1, 2008 | 01:15 PM
put a good know one in that *** out of a runing car
nousername4me
17
Aug 25, 2015 09:07 AM
yo bj
Feb 2, 2011 05:54 PM
EJ ITO
26
Mar 22, 2007 05:41 AM
Auby
Jan 18, 2007 07:26 AM
pbizzlegsr
Jul 7, 2004 10:23 PM
