Carpet cleaning
Depending on what the stain originates from, an enzyme pre-spot can be sprayed on the stain and misted along the entirety of the carpet area. From there I let the area soak for about 5 minutes and then use a foaming carpet cleaner to lift the stain out/lightly cover the other areas of the carpet. Get a carpet scrub brush to agitate the carpet to release the stain and then vacuum up with a shop-vac. Good Luck!
I have a hop van and also a bissel green machine, it really helps getting the carpets clean, it just pulls out nasty brown foam over and over. not as good as an extractor but its helpful. I just use APC brushed in.
