Project prelude
Old Nov 30, 2008 | 08:12 AM
h22abomb's Avatar
Default Project prelude
My friend and I have decided to do engine internal work to my car. I plan on bulding it for turbo, so I am going to go with lower compression pistons and such.
Last edited by h22abomb; Nov 30, 2008 at 08:44 AM. Reason: Lack of dictionary..lmao
Old Nov 30, 2008 | 08:43 AM
h22abomb's Avatar
Last night we put some low compression pistons from his old 'lude in my car. It doesn't want to start now. did we do something wrong?
Old Nov 30, 2008 | 09:57 AM
mattsnooz's Avatar
mmmm...timing perhaps? What happens when you hit ignition? Does it crank but just doesn't fire up?
Old Nov 30, 2008 | 10:08 AM
shutta's Avatar
Lack of information here.. what is happening to your car. was the motor out of the car and you put the pistons in and then it's not cranking? cranking but not starting up? details details details
Old Nov 30, 2008 | 10:17 AM
98vtec's Avatar
moderator emeritus
having a project threads means presenting details.
Old Nov 30, 2008 | 10:39 AM
h22abomb's Avatar
It will crank, but not start. are low compression pistons bad or something?
Old Nov 30, 2008 | 10:40 AM
h22abomb's Avatar
Ok, My dad told me what was wrong. When we took my freinds old h22 stock pistons, and made the for lower compression I gues we did a no no. Is it bad to have holes in your pistons?
Old Nov 30, 2008 | 10:47 AM
shutta's Avatar
what the hell?.... please tell me someone didn't drill out you pistons to make them low compression... post pics of what you have if you can
Old Nov 30, 2008 | 10:50 AM
prelude_93vtec's Avatar
What do you mean modifying stock pistons for lower compression?
Old Nov 30, 2008 | 10:53 AM
h22abomb's Avatar
We drilled 4 small holes in them, but isn't that good? I thought you needed lower compression for turbo?
Also, I dont have a camera, or I would post pics. I might be able to sketch something up real quick tho.
Old Nov 30, 2008 | 10:55 AM
shutta's Avatar
if you drilled into the pistons to make them lower compression that is BAD. Try to sketch up what you did. who told you it was ok to drill the pistons?
Old Nov 30, 2008 | 11:00 AM
h22abomb's Avatar
Something like this:
Is it good or no?
h22abomb's Avatar
Is this ok?
Old Nov 30, 2008 | 11:02 AM
h22abomb's Avatar
I wish I could take a picture. we did a really good job, we even polished the and every thing.
Old Nov 30, 2008 | 11:07 AM
h22abomb's Avatar
We just came to the conclusion that it would work (my friend and I)
Old Nov 30, 2008 | 11:23 AM
acidboi83's Avatar
Default engine
get a ls1 ahaha jp
Old Nov 30, 2008 | 12:18 PM
98vtec's Avatar
moderator emeritus
Is it good or no?
omg. I can only hope this is a joke. Step away from your engine immediately and consult a professional. Did you drill all the way through the piston? Sure, you increase the volume but you also just completed ****ED air flow. Take a picture man, that is just flat out dumb.
Old Nov 30, 2008 | 12:42 PM
meanshyguy's Avatar
First time I hear about someone doing this, who did you get advise from? Do you have the turbo ready? cuz without a turbo, lower compression means loss of power, plus you need to tune it too, it's not that simple.
Old Nov 30, 2008 | 01:20 PM
Giant_Bean's Avatar
did you not read my post in your last thread? namely this:
modifying cars goes like this:
fast & cheap=not reliable,
cheap and reliable=not fast,
fast and reliable=not cheap.
you just tried the fast and cheap, and now you are finding out why it doesn't work.
Old Nov 30, 2008 | 02:50 PM
teefunk01's Avatar
lol I hope this is a joke
Old Nov 30, 2008 | 06:13 PM
h22abomb's Avatar
So, I take it that we messed up then? Yes, the holes go all the way through. I'd rather not take my engine apart to take pictures, If I dont have to. Even if I took it back apart, I would then have to borrow a camera.Back on topic: Can I fix this or not? I really dont want to take my engine apart.
Old Nov 30, 2008 | 06:18 PM
Kronn 98SH's Avatar
Answer: go PURCHASE low-compression pistons, rip your engine apart, replace the f*cked pistons with the purchased pistons, and keep the drill away from your car.
Old Nov 30, 2008 | 06:30 PM
Giant_Bean's Avatar
purchase FRM compatible pistons, or sleeve the block, don't want him messing things up worse than he already has.
and for future reference, a motor needs some compression to work, putting holes all the way through the piston=no compression. You and your friend need to do a lot more research before you go modifying anything else on your car.
Old Nov 30, 2008 | 06:38 PM
92hondalude's Avatar
april fooooooollllls!
crap its not april. i hope this is a joke.
Old Nov 30, 2008 | 06:42 PM
cdrift's Avatar
next time just light up a match and burn your money, instead of modifying parts that you don't have the tools or the know how of messing with, that might be easier.
