Trans diagnosis?
Old Nov 30, 2008 | 06:11 AM
Hal9000's Avatar
Default Trans diagnosis?
The used 5 speed trans I bought for the auto/manual swap (in my '88 crx DX) turned out to be no good. So now I'm on the prowl for a replacement. I was hoping to find one this weekend, but surprisingly got skunked. However, there is one guy local to me selling an '88 civic DX that doesn't run. I may use that as a donor car.
But the seller said that the trans was hard to shift into second, and had a tendency to "slip" in 3rd.... He's not exactly mechanically inclined so his descriptions are suspect, but the first thing I thought was "bad clutch" until he said the prev owner had replaced the clutch....
Do these symptoms sound like anything other than a bad clutch to anybody? I just want to make sure there are no red flags before I risk installing another bad transmission.
Old Dec 1, 2008 | 06:01 AM
Hal9000's Avatar
I assume that no replies means that there are no obvious known issues that match these symptoms (aside from the clutch). I guess that's a good thing.
I'm going to go look at the car today. If it looks good enough to part out, I'll probably grab it. Can anybody tell me the high value items that I should be sure to pull/sell?
Old Dec 1, 2008 | 03:20 PM
1fastefhatch's Avatar
I would say its a bad trans i have been through 5 or 6 one felt like that ended up throwing the spider gears out the bottom??
journeyquest
Mar 11, 2013 05:04 AM
91efhbsi
Jun 1, 2008 05:49 PM
innes887
Apr 6, 2007 09:46 AM
Civiclized
Mar 17, 2006 02:15 PM
EF_yo_89
Dec 24, 2003 03:28 PM
