PLZ Help identifying tranny parts * Diagram provided*
Can anyone please help me identify what item #8 includes? I need the names of all of those parts, and thanks in advanced!
http://www.hondaautomotiveparts.com/...INSHAFT+(V-TEC)
Sorry if I sounded kind of demanding! I really hope to get the names of those 6 parts in that set! English is not my 1st language, and it kind of brings a challenge being such a CONSTANT user of H-T, and then having to translate to explain things over here. . . . thanks in advanced!
#8 is a sleeve, your going to have several ones like the 1-2 sleeve 3-4 sleeve and the 5-rev sleeve. the two parts on the outside are synchros then moving in are blocking rings then the speed gear.
Part #17 = needle bearing
Part #3 = mainshaft 3rd gear
Next comes the 3rd/4th gears synchro set, which from left to right in your drawing is made up of the following six parts whose names you want:
3rd gear synchro ring
3rd gear synchro spring
3rd/4th gears synchro sleeve
3rd/4th gears synchro hub
4th gear synchro spring
4th gear synchro ring
