Mid-Atlantic (Sales) VA, DC, and MD
1995 Accord ex for sale
Old Nov 29, 2008 | 07:11 PM
Purple-skunk's Avatar
Default 1995 Accord ex for sale
Car is in rockville, md
Sorry, forgot a price
ASKING 3700!! obo
The sole reason for this sale is a car that I have been watching for over a year has finally come up for sale. If the car sells, then this is off the block. Period
170k miles on it currently
Fully Loaded with all options (Special edition)
Full Leather interior
The car hasnt been in any accidents of any form. I actually bought it from the original owner with all (and I mean ALL ) paper work. I even got the red title from when the car was financed from the bank
EXTERIOR
The car was just clay barred 3 weeks ago and waxed with mother's 3 stage treatment. The body still does have 15+ year old marks, but definitely nothing major.
Its also missing the driver's side front fender molding and there are two dents in the hood from when not one, BUT TWO separate SUV's backed up into the car within 1 week!!! No note, nothing, just left
INTERIOR
The driver's seat has the famous tear in the door side bolster. Hasnt much affected me as the only time my body comes into contact with it is ingress/digress from the car. The carpets are in good condition with the leather having just scuffs from normal everyday use and hands. Same goes for the handbrake (basically just hand usage to the leather covering on the e brake is dirty)
The door lock actuator makes noise once the interior electronic lock to close the locks engages. Doesnt really affect much and just started recently. Actuator is around 60 new.
Also, the window on **** way up, will sporadically get stuck on its way up. If you pull the window in though, it comes up normally. Doesnt happen all the time, and again, nothing serious as the windows work. I will take the panel off sometime in the coming weeks and grease up the tracks since this is a common issue with accords of this generation
WHEELS/SUSPENSION/BRAKES
The tires on the front are 50 series and the back are 60 series. I just recently had a flat so I replaced the two front tires with some parts I had laying around from previous vehicles. They are Kumho ECSTA Supra with about 80% tread left. The rears are like 40k miles tires. Also, left front wheel is bent ever so slightly, so you can feel the imperfection while entering/exiting a right turn on/off ramp. Its also evident at above normal highway speeds. Left turns are fine. The wheel did balance as I took it a very good friends shop and I watched him balance it and he showed me also how the wheel had an imperfection in it. Said it was a-ok, just more of an annoyance and nitpicking.
Car does need rotors. The car stops just fine (and no noise) and the pads have lots of meat left, but to me it looks like some particles got between pads and rotors and left a few tiny grooves in the front rotors. The right rear rotor has a little rust buildup (only cosmetic issue and again, does not affect braking)
MAINTENANCE
All kept up. Just changed the oil with high mileage NON SYNTHETIC oil (reason is because if you have been using no synthetic oil and you change to synthetic, because the oil is much thinner than regular oil, it tends to find its way thru seals). Oil change has about 600 miles on it. Filter and drain plug also changed as well (I normally do all of them every 3-5 k miles)
I will have to go home though and sort thru the folder with receipts and all but I am pretty sure the major stuff (clutch, water pump, all belts, etc) were sorted
The car passed inspection and emissions recently (with the car in above condition mind you) too so everything should be good to go.
Ahhhhhh, I think thats it !!
Let me know
Serious offers/buyers.
Pics on monday
Negative post will be reported IMMEDIATELY, and will not be tolerated. I will also not respond to negative post. Simple and clear as crystal
Old Nov 30, 2008 | 03:55 AM
GUA-D'zCb-7's Avatar
pics
Old Nov 30, 2008 | 12:45 PM
K.Doe[shift]'s Avatar
pics please
Old Nov 30, 2008 | 07:45 PM
As I mentioned, they will be up sometime tomorrow!!
I had to work today (plus it was raining, sooooo...........)
I will do it first thing in the morning. Promise
Looking at the forecast for tomorrow, and its looking pretty good to take pics in the morning!!
Old Dec 1, 2008 | 07:36 PM
Pics as promised:
Old Dec 3, 2008 | 05:03 AM
up
Old Dec 4, 2008 | 05:06 AM
up
Old Dec 4, 2008 | 09:45 PM
bump
Old Dec 6, 2008 | 09:42 AM
up
Old Dec 8, 2008 | 01:35 PM
bump
Old Dec 10, 2008 | 05:53 AM
bump
Old Dec 11, 2008 | 12:49 PM
up
Old Dec 12, 2008 | 04:34 PM
taking reasonable offers
Old Dec 13, 2008 | 11:27 PM
Lets get this sold!!! Taking offers
Purple-skunk
Dec 13, 2008 11:29 PM
chidoks
Dec 26, 2006 07:32 AM
defylogik
Jun 26, 2002 12:06 PM
Accords 4U2 NV
Mar 21, 2002 04:11 PM
